add lift to my exsisting lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by SBbeachTOY, Feb 23, 2012.
  1. Feb 23, 2012 at 9:29 AM
    SBbeachTOY
    SBbeachTOY [OP] Member
    santa barbara
    '02 4x4 dbl cab limited edition
    Traded front painted bumped for chrome bumper. My truck can with the chrome package, except the front bumper, so I found someone who wanted to trade. Front chrome bumper wears better (no paint chips from other traffic)!
    New guy to tacoworld.
    Im lookin to go higher!
    I have toytech coilovers on front, and complete new leaf packs from OME on the rear. I am looking to add 1 or 2 more inches to that. Is it possible with spacers or any other hardware?
  2. Feb 23, 2012 at 9:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    ^that^
    You're only looking for trouble (component failure) if you stack a suspension lift.
    You could add a body lift if you really want it that bad.
  3. Feb 23, 2012 at 10:21 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
  4. Feb 23, 2012 at 10:23 AM
    04taco2wd
    04taco2wd Take your flame, ignite the world!!!!
    Colby
    Southern Pitt,NC
    06 AC 4x4 SR5
    6" Fabtech Lift, Custom bedside decals, ICON C/Os, 17x9 Cruiser Alloys, 33x12.5x17 Coopers, UWS Lopro Toolbox, more to come...
    Why do you want more lift? Bigger tires? Get the razor out and start trimming.
  5. Feb 23, 2012 at 10:29 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Nothing to trim on a steel truck = 2nd gen body MODS require 2 "tools"
    a razor & a heat or hot glue gun.....:p
    j/k
  6. Feb 23, 2012 at 10:30 AM
    04taco2wd
    Colby
    Southern Pitt,NC
    06 AC 4x4 SR5
    Haha. Didnt think about him having a 1st gen. Carry on
  7. Feb 24, 2012 at 7:12 AM
    SBbeachTOY
    santa barbara
    The problem is I have to much tire rub. I would like to just raise it enough to have more clearance. Add one inch suspension if possible!
  8. Feb 24, 2012 at 7:17 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    What wheels and tire are you running? Is this street rubbing or off road?
  9. Feb 24, 2012 at 8:54 AM
    SBbeachTOY
    santa barbara
    Yes, that is the main problem.
    I have BFG'S ALL TERRAIN LT285 75 R16, and MOTO METAL 955's.
    Rubs on the frame when I turn fully, no rubbing on fenders when im on street, but rubs on fenders when im on drit.
  10. Feb 24, 2012 at 8:56 AM
    TacoMX
    Jonathan
    Deltona, Florida
    Have you done the pinch weld mod yet (pound down/ground down the pinch weld in the wheel well) and Wheel spacers like spider trax will stop you from rubbing on your frame.
    More lift wont stop the wheels from rubbing the frame, and some simple hand tool work will help you avoid having to run a POS body lift.
  11. Feb 24, 2012 at 9:15 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    More lift really won't help you. The problem is your wheels. The 955's are a 4.5" backspacing. Magic number on a first gen for 285's is 4" BS.
    Hell I still used to rub the frame even with the 4" when wheeling (full lock/compression).
    My guess is your rubbing on the frame behind the wheels (closer to the cab of the truck. You can try getting some aftermarket UCA's and get your alignment shop to add some caster, but you'll most likely still rub with the 4.5" BS.
  12. Feb 24, 2012 at 10:49 AM
    SBbeachTOY
    santa barbara
    No mods in wheel wells yet.
    What are the dimensions on the spider trax?
  13. Feb 24, 2012 at 11:25 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  14. Feb 24, 2012 at 11:31 AM
    98tacoma27
    Ben
    Not Beech Creek
  15. Feb 24, 2012 at 1:09 PM
    SBbeachTOY
    santa barbara
    i can live with alittle tire rub on the frame, my main concern is ripping out my fenders. A body lift would help, but im try to stay with suspension lift. If I max out the hight of the coilovers in front, is there an easy fix for the rear?
  16. Feb 24, 2012 at 1:19 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    The following thread will help you with the rear. I followed the suggestions and re-formed my fender flares with a heat gun to alleviate the rubbing.
    http://www.expeditionswest.com/equipment/tacoma/bfg_mt_km.html
    The front will require modifying the pinch weld ( I removed mine) and trimming some plastic. On my truck, I have to modify/remove the windshield washer reservoir. Your results may vary.
    The lift will only help you until you flex the suspension enough to bring the tire in contact with the body. The only that changes is where in your suspension travel it occurs. No way to get rid of it entirely without trimming.
  17. Feb 25, 2012 at 7:48 PM
    SBbeachTOY
    santa barbara
    Thanks! That looks like a great start.
    Just curious.. has anybody successfully reshaped color coded fenders with a heat gun enough to add a considerable amount of clearance?
  18. Feb 25, 2012 at 8:22 PM
    TacoTaro
    TacoTaro Well-Known Member
    Los Angeles
    04 DC 4x4
    King Coilovers, Light Racing UCA, OME Dakar leafs w/ extra leaf and SB10" Bilstein 7100's and a U-bolt flip. 4.56's, eLocker rear, ARB front, Marlin rear bumper, ARB Bull Bar w/ Warn M8000. BAMF Sliders. Manual hub conversion with functioning ABS. Tundra front brakes. Manual hub conversion with functioning ABS. SCS F-5's w/ 255/85 Toyo MT's
    Everyone else has already covered the front.
    Do you have the extra leaf for your OME's yet? That will bring the back up a lot. I got over an inch from the extra leaf. And I have a DC w/ a shell and and a rear bumper. It's perfect when I load the truck up or put a motorcycle in the back, but it sits kinda high with just the shell.
    Or a shackle.
  19. Feb 26, 2012 at 9:23 AM
    SBbeachTOY
    santa barbara
    nothing done to the rear besides the new OME leaf pack from toytech.
  20. Feb 26, 2012 at 9:50 AM
    TacoTaro
    Los Angeles
    04 DC 4x4
    Then you could add the OME extra leaf. It's cheap and gave me at least an inch. But unless you have weight on the rear it may sit up too high. Like I said I have some weight on mine and it still sits too high in the back. The problem, as already mentioned, you can only lift the front so much without running into problems.
