Add LSD?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by metrick1215, Sep 12, 2013.
  1. Sep 12, 2013 at 10:03 AM
    metrick1215
    metrick1215 [OP] Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    Ok so i was wondering if it is possible to add LSD or some kind of traction control for less than buying a locker for my truck. Id like to do stock LSD because it would be less of a headache i would think... I have a 2007 Prerunner bare minimum (no options whatsoever) ive been slowly adding things to do what i want it to. Cruise, fogs in next month, and wiper switch... I know i have the plug behind the panel for where the LSD switch would go but i havent traced all the wireing back... any help would be great! thank you
  2. Sep 12, 2013 at 11:33 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    So you are sure your truck doesnt have a lsd from the factory? If not you could put one in. They arent cheap though.
  3. Sep 15, 2013 at 6:24 AM
    metrick1215
    Habersham GA..
    as far as i know my truck doesnt.. I dont have any VSC or LSD switch and no lights for it either.. so i assume not..but you know what happens when you assume..
  4. Sep 15, 2013 at 6:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check the diff (rear) and see if it says anything about using an LSD addative. If not, you probably don't have an LS Diff, and can add one, like a Detroit Tru track.
  5. Sep 15, 2013 at 7:12 AM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    This is what you are looking for:
    All the buttons, and electronics didn't replace the mechanical LSD's till 2009.
    David
  6. Sep 15, 2013 at 7:28 AM
    metrick1215
    Habersham GA..
    ok so no LSD oil sticker.. So what size do i need ive seen a few different sizes online. How much should i be looking at paying? any other brand to look at other than truetrac? im not looking to dump $1000's into this..
  7. Sep 15, 2013 at 9:58 AM
    metrick1215
    Habersham GA..
    This maybe... its 300.00?? Also anyone know where i can see a write up on how to install.. Im pretty mechanically inclined and have a friend with a lift and shop...
  8. Sep 15, 2013 at 12:42 PM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    How about finding the whole axle assembly from a junk yard.
