Add OEM cruise and intermitent wipers 2012 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xglasman, Oct 26, 2011.
  1. Oct 26, 2011 at 9:00 PM
    xglasman
    xglasman [OP] Member
    I just purchased a 2012 regular cab Tacoma and would like to add cruise control and intermitent wipers. Anyone tried this yet?
    Thanks
  2. Oct 26, 2011 at 9:08 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Call toyota parts dept and ask what the part#'s are for the switches. If they are the same as what are in the threads about adding these to 2nd gens then I would assume you'd be OK.
  3. Oct 27, 2011 at 1:13 PM
    xglasman
    I think they changed the steering wheel for 2012.
  4. Oct 27, 2011 at 1:14 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Not to sure
    welcome to TW
  5. Jan 20, 2012 at 1:22 PM
    dnorrell
    dnorrell Member
    Adam
    Castle Rock, CO
    I would like to bump this thread. I am thinking of buying a 2.7 4x4 regular cab, and while I love manual windows and locks, I'm a CC fiend. I have called and verified that the 2012 models that come with CC standard use the same part number as those that have bought to add CC to their regular cabs. It seems like it may still be plug-n-play, but I'm not sure.
    Has anyone with a '12 yet tried this?
    Thanks!
    A-very-new-member Adam
  6. Jan 21, 2012 at 8:36 AM
    xglasman
    I did end up installing cruise on my 2012.. works like a champ.. the steering wheel cover is different if you order an OEM, I posted the part number in a thread here somewhere. Here is the number for the OEM steering wheel cover 45186-04030-B0. I ordered the kit for a 2011 from Brandon Distributing and ordered the cover from Toyota.
  7. Jan 22, 2012 at 7:34 AM
    dnorrell
    dnorrell Member
    Adam
    Castle Rock, CO
    Fantastic! That is great news. Thank you for sharing the additional info too.
  8. Feb 20, 2012 at 10:54 AM
    swabbie48
    swabbie48 New Member
    2012 Tacoma Long Bed
    Cruise, intermittent wipers, Access tonneau cover
    I just added cruise and intermittent wipers to my 2012 long bed.....Just can't keep a constant speed going at my age. Did the same as 'xglasman'....ordered the cruise from Brandon, and ordered the intermitten wiper arm and the cruise steering wheel cover ($4.00) from Toyotaparts.com.....Took longer to get the panels off and identify the correct connectors than it did to install the wires. But, they both work great!
  9. Feb 23, 2012 at 12:30 PM
    Ming42083
    Ming42083 Member
    Adam
    Peoria, IL
    2012 reg cab 4x4
    Has anyone done a install on a 2012 with a manual trans? Is there still a pre-wired connector for the clutch switch?
  10. May 2, 2012 at 6:15 PM
    Ebby1600
    Ebby1600 Member
    Ebby
    Planet Earth
    2012 Black Regular Cab 4x4 AT
    Rubber floor mats...lol Intermittent wipers
    Ok I installed the intermittent wiper stalk on my 2012 Regular cab using the part number from 2011. All is well and it was an easy install. I'm leaning towards doing the cruise control but have a question. Are all the electronics that control the throttle contained in the cruise stalK? Is the gas pedal actually an electronic device? In other words do I have to install (purchase) anything else besides the cruise stalk, wire and side cover? I know my newbie is showing...
  11. May 2, 2012 at 6:35 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The electronics are actually in the ECU. The stalk is nothing more than 4 switches (might be some electronics in there, but the guts are in the computer).
    Yes, the gas pedal is little more than a potentiometer or positioner that feeds a desired throttle position to the ECU. The ECU controls a servo on the throttle body. It's all fly by wire now.
    MOST trucks it's simply plug and play.
    There have been some reports of RC-Base models produced in Mexico that are missing the connecting wire from the column to the ECU, but that can be added with a little work.
    My '08 RC Base was plug and play.
  12. May 2, 2012 at 6:46 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    if you have manual tranny there is a clutch switch. if auto then stalk, cover and wire is it
  13. May 3, 2012 at 10:07 AM
    Ebby1600
    Ebby1600 Member
    Ebby
    Planet Earth
    For about a hundred bucks I can get the parts to do the cruise control. Why not. Thanks for the info on how the gas pedal/throttle works electronically. I have the automatic so no clutch switch needed.
  14. May 3, 2012 at 6:01 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yup.
    Toyota of Dallas I paid about $250 shipped for everything for the cruise and wipers (plus a few extra parts... oil filters and an air filter)
  15. May 4, 2012 at 11:14 AM
    Ming42083
    Ming42083 Member
    Adam
    Peoria, IL
    2012 reg cab 4x4
  16. May 4, 2012 at 2:43 PM
    Ebby1600
    Ebby1600 Member
    Ebby
    Planet Earth
    So I took the plunge and ordered the parts from 1stToyota. In my order comments I mentioned that the idea for cruise in a regular cab came from a Tacoma forum and if by chance I did not order the correct parts would they be so kind to make the correction and send the correct parts. My order was accepted and in the confirmation contents was this message.
    "We here at Toyota do not add on cruise control onto model that did not come from the factory with cruise control. If you know that the parts that you are ordering are correct, we will continue with your order. However, if the parts are incorrect, you will be responsible for the return shipping costs and you will be charged a 15% restocking fee."
    These are the parts I ordered:
    84632-08021 Cruise control switch
    45186-0C020-B0 Steering wheel cover (Forum stated 2012 P/N due to new steering wheel design.)
    84633-04020 Cruise control wire
    I have the two screws to attach the stalk to the frame.
    I'll keep you posted on how it all turns out.
  17. May 4, 2012 at 7:22 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yup... CYA.
    A few have been successful in getting a tech they know to order and install the proper parts, but the official line, and anything they are going to put in writing, will not support the addition of factory parts that were not factory original unless they were an option on that model, such as the RS3000 alarm system on my wife's Rav4.
  18. May 10, 2012 at 3:06 PM
    Ebby1600
    Ebby1600 Member
    Ebby
    Planet Earth
    I have the Regular Cab 2012 I4 4x4 auto and installed the stalk, connector wire and cover as stated in http://www.toyotanation.com/forum/61-2nd-generation-2005/171992-diy-oem-cruise-control.html.
    No joy:mad: . The parts went in just as pictured in the Toyota Nation post but the test drive had negative results for the cruise control
    I understand that some RC Tacoma are missing a wire from the ECU to the steering wheel. Tacoma's built in Mexico. I checked my door jamb and my truck was made in Texas Nov 2011. That's not Mexico but maybe it applies the same way.
    Does someone have a ready handle on where the post is that describes how to add the missing wire from the ECU? if so, I'll do that step and see if the cruise works. If it doesn't work I may uninstall and do a FS post on the parts I purchased.
    Thanks
  19. May 12, 2012 at 7:41 AM
    Ming42083
    Ming42083 Member
    Adam
    Peoria, IL
    2012 reg cab 4x4
