Add power to compensate for tire size increase
Discussion in 'Performance and Tuning' started by cdjudd, Aug 22, 2017.
  1. Aug 23, 2017 at 11:18 PM
    7ender
    7ender Well-Known Member
    TRD forced induction
  2. Sep 4, 2017 at 2:28 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Because bolt-on is easier than fabrication, perhaps? :notsure:
    yota243 likes this.
  3. Sep 4, 2017 at 2:36 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Because a supercharger is bolt on and an LS swap isn't.
  4. Oct 17, 2017 at 8:40 AM
    1997tacomav6
    Denver
    Because my supercharger was 2500 new and installed in 3 hours :)
    timothom[QUOTED] and jojotoo like this.
  5. Oct 17, 2017 at 5:24 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Warranty, bolt on, but 5 grand buys a new engine and a new trans?
  6. Oct 18, 2017 at 7:16 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Yea, my number is off there. If you had shop and tools and could do your own fab, you might be able to pull it off if you found a good deal on a used LS/motor tranny for 5 grand. But it's probably gonna cost more. My bad.
