Add shock boots to Icon rear shocks?
Discussion in 'Suspension' started by iJDub, Jul 14, 2013.
  1. Jul 14, 2013 at 7:57 PM
    iJDub
    iJDub [OP] Well-Known Member
    Anyone here add some shock boots to the rears? Would like to protect the shaft.
  2. Jul 15, 2013 at 7:56 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Yes, I installed boots on mine. Simple and easy to do.
    PK
  3. Jul 16, 2013 at 9:42 PM
    iJDub
    You have Icons?
  4. Jul 16, 2013 at 9:52 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^PSU has the older pre-VS series shocks.
