ADD to Manual Hub conversion?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kleenax, Sep 30, 2021.
  1. Sep 30, 2021 at 10:39 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    You can still do this with a manual setup, just leave the transfer case in 2WD but leave the hubs locked and never have to get out of your truck.
  2. Sep 30, 2021 at 10:54 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    There are a few reasons why people opt to go to Manual hubs.
    When converting to 4wd from Prerunnner, it's by far the simpler solution than ADD
    Also... ADD not actuating properly is also a reason. That is a known, and common problem with the ADD system, and pretty much any "Automatic 4wd" system. (As a matter of fact, there's a guy in the "what have you done 1st gen" thread, right now, trying to figure out why his 4wd wont engage... it comes up relatively often). I have seen it happen on the trail a number of times... not just with Toyotas.
    CVs aren't spinning... Forget the gas milage nonsense, I don't think you would even honestly be able to tell the difference. But the spider gears are humming in there at highway speed. I'd prefer them to stay still, less wear. But the most important part is the CV boots aren't wearing out. CV boots are a pain in the dick, I'd prefer not having to deal with them any more often than neccesary.
    Trail repair... if you break a CV, flip the dial on that side to free and drive to a safer, better spot to fix it. ADD = you have to fix it where it broke, or creep along with the CV clunking around in there (still turning) and risk further damage. It's also easier to swap a manual CV than an ADD. The torque value on the CV nut is pretty high, for one thing.
    The manual CV shaft is weaker thing. Yes, the outer shaft on manual CVs is thinner. Yes, that may make it weaker. BUT.... The stub shaft in the ADD diff is weaker than the full shaft in the manual diff tube. A repair, replacing a CV is much easier than trying to replace a stub shaft.
    The whole I don't want to get out and flip the hubs thing is dumb (to me)... I'm already out of the truck airing down or airing up anyway.
    Area51Runner and SLAPS 65 like this.
  3. Sep 30, 2021 at 11:02 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Go new, as listed above. Or, find a junkyard that has a clean manual hub truck, buy the knuckles/hubs, cv axles, and tube. My local yard sold me everything for $150.
    With a little machining and fab work, 100 Series Land Cruiser IFS CV axles might be a nice upgrade over the tiny Gen 1 Taco stock items.
  4. Sep 30, 2021 at 11:25 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Aisin + Asian = Aisian
    Icwutudidthere :laughing:
  5. Sep 30, 2021 at 11:27 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    LMAO. Honestly just a typo
    Kwikvette[QUOTED] likes this.
  6. Sep 30, 2021 at 12:30 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Lol its all about those IG points bruh
  7. Sep 30, 2021 at 2:31 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I'm trying real hard to get my head around this. It started to snow hard so I have to pull over lock in the hubs get back in the truck then I have to engage the ADD just what exactly have I gained? Maybe I would have to replace some parts say in 250K? I have all ready replaced one front wheel bearing the mod wouldn't help that one damn bit!
  8. Sep 30, 2021 at 2:33 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    If you are engaging the ADD, you don't have manual hubs to get out and lock in.
    SR-71A and Black DOG Lila like this.
  9. Sep 30, 2021 at 2:56 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    You have ADD and locking hubs?
    Weird
  10. Sep 30, 2021 at 2:58 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You're confusing yourself into thinking you have ADD and manual hubs.
    You have one, or the other.
    Are you referring to your transfer case?
    Only two variants exist for a Tacoma; push button or J shift.
    Black DOG Lila likes this.
  11. Sep 30, 2021 at 3:24 PM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    I’m understanding what he’s asking. He has ADD and is asking what he will gain by adding just the hubs, and not converting the differential.
    Basically the same question that I asked myself. Converting over to the hubs will stop the axles and spider gears from turning. If cv boots aren’t giving you trouble then it’s really not worth the hassle or money in my opinion. Nobody is going to get out and air down and lock the hubs in just because it started snowing really hard. It’s just too easy to pull that short shifter back at road speed and the 4x4 light switches on.
  12. Sep 30, 2021 at 4:13 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    It is easy, until it doesn’t work. Manual always works. You can leave manuals locked at the wheels and then shift your transfer case so your crocs don’t get moist in the snow if you want during the winter. If you try to wrap your head around it too much then you probably don’t need or want it.
    DJB1 and Kleenax[OP] like this.
  13. Sep 30, 2021 at 4:58 PM
    wesb1023
    Westley
    Eastern NC
    04 Double Cab
    I don’t have crocs, I’m not some bitch like you’re assuming.
    I am a professional automotive and equipment technician. I clearly understand the pros and cons of both systems. I happen to have the ADD and decided against the conversion because the cons outweighs the pros in my scenario. I do think it would be really nice to ride down the road without my cv’s and spider gears spinning, that appeals to me yet I decided against it.
    If it doesn’t work, I fix it myself.
    I’ve actually had an argument with one of my friends because he was ordering a brand new truck. He special ordered a Ford F-150….and paid more for it because he didn’t want power windows. He wanted manual windows “because they never break” “them lectric windrs all time messin up” he said.
    In fact I’ve replaced just as many manual window regulators as I have power window regulators and motors. The manual regulators are way harder to change. I know I’m going a little off base here because I’m bringing in Ford on this, but I’ve actually also worked on just as many manual 4x4 engagement trucks as push button while I worked at the Ford dealership. The concern was “no 4x4”. That’s across the spectrum on all makes.
    The largest weighing pro that I have is the ability, knowledge, shop, lift, and all tools needed to fix anything myself. I don’t have to pay anyone to wrench on my truck, except for alignments. I don’t have an alignment machine, or a wheel balancer dammit.
    SR-71A and zippsub9[QUOTED] like this.
  14. Oct 1, 2021 at 3:27 PM
    Kleenax
    Kleenax [OP] Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    Thanks zippsub9; appreciated! Here were my thoughts: my truck is 20 years old, 155K miles, I plan on keeping it til it DROPS, so I was looking at ways to make it a "little" less prone to break-downs (moving parts, etc), also, I am certain that I will soon have to be replacing front wheel bearings, CV/axles, etc., so I figured while I was in there, what-the-hell..... ALL of my former rigs had lock-out hubs, and ADD just seems to make a lot more wear n' tear on the highway (which I am unfortunately on more than trails).
    The reason that I wanted to look at a "KIT" was simply to see what parts are required, and what this swap entails, and whether I want to even tackle it or just replace as I go along.....
    zippsub9[QUOTED] likes this.
  15. Oct 1, 2021 at 4:47 PM
    #35
    Kwikvette
    Fresno County
    4 run, 2 don't
    :burp:
    0xDEADBEEF likes this.
  16. Oct 8, 2021 at 5:49 AM
    #36
    SR-71A
    Zack
    Southern Maine
    I agree with what you are trying to get at. Just because its manually engaged does not mean it wont break.. Like I said before, I think the factory system is good for 99% of people like us who actually use our trucks. Just gotta keep those actuators dry. I can see the possible advantage of not spinning CVs all the time to reduce boot wear, but if thats the case maybe you should have less lift haha
    Which reminds me I need to run new ADD & diff breather lines :anonymous:
    wesb1023[QUOTED] and Kwikvette like this.
  17. Oct 8, 2021 at 10:12 AM
    #37
    Running Board Man
    Running Board Man Well-Known Member
    The cv axles not being put together allow him to make another thread about cv joint boots
  18. Sep 27, 2023 at 6:21 PM
    #38
    RedShaggyTaco
    RedShaggyTaco May The Force Be With You !
    PNW
    98 TRD SR5 4x4
    OME Dakar heavy Leafs, OME Coil overs, Bilstein 5100s all around, Coastal Off-Road front bumper, 17in FJ steelies with 33in Geolandar MT, RCI engine and transmission skids, badlands 9k lb winch, ARE shell
    So I can't find the thread but you mentioned having both add and manual locking hubs. So there was no issue just install hubs and your good to go? I have new manual locking hubs and gaskets and want piece of mind if I were to break a cv that I can limp out safer off road. Am I correct and this will work as stated? How do you like your set up?
