ADD W1 VER1 Oil Catch Can Group Buy "FEELER FAIL"-Please delete!!
Discussion in 'Group Buys' started by Rusty15Tacoma, Sep 29, 2015.
  1. Oct 15, 2015 at 4:27 AM
    #81
    ThomasMore66
    Dallas/Fort Worth & Durango
    I was stunned with how much I collected. I have the dipstick version in ricer blue.
  2. Oct 15, 2015 at 6:08 AM
    #82
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yea so it looks like these can be had at or cheaper than the GB price these ebay sellers are trying to give us a "deal" on. As i said before, keep an eye out on ebay and you'll see them pop up cheaply from time to time
    #82
  3. Oct 15, 2015 at 7:59 AM
    #83
    Russtoy
    Russtoy Well-Known Member
    Russel
    Ohio
    2000 4Runner SR5
    This is the one I bought also. Very nice can...like the fact there's multiple tier inside to actually help separate the oil/crud from the engines ventings/vapors. I just installed a supercharger, so I was just inside my engine. My intake was completely covered with a black oily crud. I have one of these cans on my Turbo Diesel, but didn't have one on my 4Runner. Was lead to believe N/A engine didn't need them...only supercharged or turbo's needed them. Well I'm here to tell ya that's Bull Crap!! If you what a clean running engine, you should be running one of these!
    Just remember this...the EPA doesn't care or gives a rats butt how long your engine last or how much it cost you in maintenance bills (Seafoam/valve jobs/intake removel cleaning) or how much fuel mileage you lose!! It's up to you to protect and keep your engine healthy so it will last and run as efficiently as possible. I can assure you, Using one of these catch cans will help!
    The el cheapo eBay can will help some, but you might as well use a Coke can. I don't care what you pay for it...but should look for a catch can that has different chambers inside...thus allowing the oil/fumes/air to separate from one another. Leaving the oil/crude in the can and sending clean air back into your engine or vent it to the atmosphere.
    #83
  4. Oct 15, 2015 at 9:32 AM
    #84
    Rusty15Tacoma
    Rusty15Tacoma [OP] Well-Known Member
    Rusty
    San Diego
    2015 MGM TRD Offroad
    Bilstein 5100 w/ OME 886, Built Right UCA's, Dirt King LCA's, 5125 2"-2.5" lift rear shocks, Alcan HD 8pack rear, Level 8 Guardian 16" wheels, blacked out badges, 285/75R16 Hercules Trail Digger, 20% tint, BHLM Retrofit.
    If there really is no rime or reason to a brand or style, then maybe I'll do a bit more and see what else I can find. Just went with this brand because of the thread. I did read somewhere the breather style can cause a vacuum leak, but can't seem to remember if that was for s/c or not.
    I'd also refrain from using one with the side plastic tube. In my experience, any plastic tubing that is subjected to hot and cold elements at engine temperatures, will become fragile and crack or break.
  5. Oct 15, 2015 at 6:15 PM
    #85
    Tyson
    Tyson $Mr.T$
    Tyson
    Wyoming
    15' TRD off road, dbl, 6spd, 4.0L
    All-Pro UCA Stage 4 Icon lift redline hood struts interior dome and map LED lights 2 spot led pods (ditch lights) flush mount rear back up flood pods hood and bed LED lights GPS anytime mod RTMR electrical system (relays fuses etc.) weather tech floor mats anytime fog lights bixenon headlights and fogs ABS off switch anytime rear e-locker 30" OSRAM light bar (in grill) ARB CKMTA12 compressor ARB front locker Rock sliders all-pro Apex coming later: Doug Thorley long tube headers Y pipe Exhaust
    so.... the most Ideal Catch can would be.................????????
  6. Oct 15, 2015 at 9:05 PM
    #86
    ThomasMore66
    The one you own.
  7. Oct 16, 2015 at 1:03 AM
    #87
    Tyson
    Tyson $Mr.T$
    Tyson
    Wyoming
    :duel:
  8. Oct 16, 2015 at 1:34 AM
    #88
    TACTICA
    TACTICA Well-Known Member
    Stan
    North Georgia
    '15 TRD Off Road
    I'm interested in one - in black. However as many have stated, the price has to be right - and we are not there yet. Hoping we can do the GB........
  9. Oct 17, 2015 at 7:47 PM
    #89
    Rusty15Tacoma
    Rusty
    San Diego
    Well I can't seem to find a better can or deal. If you are good with the price, add your name to the list and repost. If we meet his numbers then I'll send an email letting him know and we'll follow up. If we don't meet them, well I guess I tried.
    1.
    2.
    3.
    4.
    5.
    6.
    7.
    8.
    9.
    10.
    11.
    12.
    13.
    14..
    15.
  10. Oct 17, 2015 at 8:31 PM
    #90
    Rusty15Tacoma
    Rusty
    San Diego
    http://gogoautoshop.com/oil-breather-baffled-catch-tank-can.html
    So far pricing normally on there website, shipped to my door is $82 and change. Here is the email I got for the group buy:
    ADD W1 Oil Catch Tank Can Reservoir Tank Ver.1
    15 + $79.99 ( Price Incl shipping within the US ) ( shipping to Canada or Hawaii additional $18.00 )
    50 + $75.99 ( Price Incl shipping within the US ) ( shipping to Canada or Hawaii additional $18.00 )
    80 + $69.99 ( Price Incl shipping within the US ) ( shipping to Canada or Hawaii additional $18.00 )
    AN-09 Fitting optional $3.00 each piece ( each tanks Need 2 )
    AN-10 Fitting optional $3.00 each piece ( each tanks Need 2 )
    On page 1 and 2
  11. Oct 18, 2015 at 7:40 PM
    #91
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
    I'll start....
    1. RussToy
    2.
    3.
    4.
  12. Oct 18, 2015 at 8:38 PM
    #92
    VolcomTacoma
    Jeff
    NorCal
    Why start? The price isn't group buyable...Just go on ebay and find the same thing for the same price. There's no way we get 50+ for this, and at that point its $5 off. We need to find a different vendor that's willing to drop the price a bit
    #92
  13. Oct 19, 2015 at 4:09 AM
    #93
    Rusty15Tacoma
    Rusty
    San Diego
    I've only been able to find two other vendors that look legit. One was 10% off, which was about the same, and the other didn't respond. I figured if there's 15 people willing to pay the $80 for the can, then I'd put it together for them.
    #93
  14. Oct 19, 2015 at 6:12 AM
    #94
    VolcomTacoma
    Jeff
    NorCal
    Well, more power to you, brother.
  15. Oct 19, 2015 at 6:36 AM
    #95
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
    If you know of an as good or better can, with a better price....let us know. We're open to suggestions!! The way I was looking at it...I want to buy a good can, if I can save $5 with a GB...$5 more I can put in my savings. I'd don't know...it is frustrating!!
  16. Oct 19, 2015 at 7:37 AM
    #96
    VolcomTacoma
    Jeff
    NorCal
    I
    i looked up this can and it seems pretty legit. Probably be the one i end up getting. Mostly because its baffled, if you read up on the ADD W1, some guys were having to put steel wool or the like inside to try to act as a baffle in some cases
  17. Oct 19, 2015 at 7:39 AM
    #97
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
    Better or cheaper?
    Better would be rev extreme, Mighty Mouse, elite, Norris
  18. Oct 19, 2015 at 11:44 AM
    #98
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
    1. RussToy
    2. dcsbtaco
    3.
    4.
  19. Oct 19, 2015 at 12:04 PM
    #99
    Russtoy
    Russel
    Ohio
    2000 4Runner SR5
    Your welcome @dcsbtaco
    I have this catch can and really like it...this on my diesel pickup. @VolcomTacoma if you're wanting to check up on this one...I'm game for it. It works quit well and everything comes with it. Let us know Sir.
  20. Oct 19, 2015 at 1:24 PM
    #100
    VolcomTacoma
    Jeff
    NorCal
    Oh...i was just going to order that one for myself lol. Sorry boys, I'm done running group buys on this site, to many peoppe with torches around when the slightest thing goes wrong
