Add XM to Stock Radio?
Discussion in 'Audio & Video' started by Furious George, Jan 3, 2014.
  1. Jan 3, 2014 at 4:23 PM
    Furious George
    Furious George [OP] Member
    Ontario, Canada
    2013 Access Cab TRD Off-Road
    Bone Stock
    I have a 2013 with the Touchscreen NON-Nav radio. It didn't come with XM from the factory. Would it be possible to add on a module to the factory radio to get XM reception?
    Just trying to keep things clean as far as installs go and hopefully there is a simple solution.
    Thanks for your time.
  2. Jan 3, 2014 at 4:41 PM
    Pwooly
    Pwooly Well-Known Member
    I'm looking to know the same. Weird thing is the non touch screen that comes in the cheaper models come with xm. I'm using Pandora for now over bluetooth. As a alternative solution you can get the xm app and stream it over Bluetooth.
  3. Jan 4, 2014 at 9:24 AM
    Furious George
    Ontario, Canada
    Bone Stock
    I think I found just the ticket for the 2012+ Non-Nav Touchscreen radios.
    http://store.xmfanstore.com/complete-xm-radio-install-kit-for-toyota-scion-lexus.html
    I was reading on another forum someone added this kit to his Corolla Non-Nav radio and it had seamless integration to the head unit. It had the touch screen option for XM added to the inputs and didn't affect any of the other options negatively.
    I'll be ordering this kit most likely, unless of course someone else has any other ideas?
  4. Jan 4, 2014 at 9:28 AM
    Phil5393
    Phil5393 Well-Known Member
    Phil
    Long Island, New York
    TRD Sport
    I have been wanting to do the same thing. If you order it please let me know if it works. Thanks
  5. Jan 4, 2014 at 3:57 PM
    TacoRaider
    TacoRaider Member
    Ben
    13 PreRunner
  6. Jan 5, 2014 at 9:13 AM
    Furious George
    Ontario, Canada
    Bone Stock
  7. Jan 5, 2014 at 9:54 AM
    TacoRaider
    TacoRaider Member
    Ben
    13 PreRunner
  8. Jan 6, 2014 at 7:32 AM
    Furious George
    Ontario, Canada
    Bone Stock
    Thanks TacoRaider.
  9. Oct 11, 2014 at 6:14 PM
    4tw
    4tw Member
    2013 rc 4 x
    So OK my 2013 with touch screen didnt come with XM either. Would it be smarter to change the stereo rather than spent 250 for the kit?
  10. Oct 11, 2014 at 7:46 PM
    FawkQ
    FawkQ Well-Known Member
    Alberta, Canada
    2013 TRD Sport DCSB V6 4.0 6M "The Sequel"
    If you plan on swapping out the HU, beware that lots of aftermarket HU's are XM compatible but still require a kit like this... So you'll end up paying the 250 anyway, unless you track down a HU that includes this receiver and XM antenna.
    Something to ponder/research!
  11. Oct 11, 2014 at 9:20 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    i just bought the factory xm unit for my year and bought a magnetic roof antenna. worked like a charm.
  12. Oct 12, 2014 at 4:51 AM
    MtnBiker831
    MtnBiker831 Well-Known Member
    Santa Cruz, CA
    17 Trd Pro
    Audio, lots of it
    Also check out vais tech, been using there modules for years and they work well. And if you have a compatible aftermarket radio the sxv sat tuner and ant is only $70.
  13. Oct 12, 2014 at 12:39 PM
    4tw
    4tw Member
    2013 rc 4 x
    OK yea good point thanks!
  14. Oct 12, 2014 at 1:22 PM
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    I just installed the iSimple kit from XMfanstore.com on my 2013 non-nav touchscreen radio and love it. I downloaded the install instructions from Toyota of McDonough, which was a big help.
  15. Oct 12, 2014 at 1:23 PM
    BKill
    Bill
    College Station, TX
    Oh, by the way, I also did the stealth XM antenna mount, which I'd also recommend.
  16. Oct 12, 2014 at 1:33 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Most aftermarket adapters for the xm function are less than 70.00 fwiw. Like my pioneer is only 35.00 to add the xm module and antenna to my head unit.
    Now off topic on modules but unless you're listening to the talk stations and possibly sports why not use Pandora 1 and save the 14.00 a month or however much it is now.
  17. Aug 31, 2016 at 10:53 AM
    dragonhrt
    dragonhrt Well-Known Member
    Ottawa
    07 TRD Offroad
    OME 3 Inch Lift, 5100's
    Sorry for raising an old thread, but could I get more information on this as I would like to keep my 2k13 factory while adding an integrated xm radio.
  18. Aug 31, 2016 at 7:38 PM
    BKill
    Bill
    College Station, TX
    Go to xmfanstore.com. You can buy a kit that includes a tuner, a gateway interface, harness, and antenna. Sorry, I didn't take photos of my install, but if you do a search, either on this forum, or online, you should find pretty detailed instructions on he installation. The kit will also have instructions, although they're not as in depth. If you're interested in doing the stealth antenna installation, which is what I did, do a search on this forum and you'll find photos of the install.
