Added 3.5 speakers in place of stock tweeters.
Discussion in 'Audio & Video' started by PETEREDGE, Aug 28, 2014.
  1. Feb 10, 2019 at 5:26 AM
    #41
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    A capacitor acts as a high pass filter - in other words it blocks lower frequencies. The frequencies blocked are determined by the value of the cap and the impedance of the load. You can install it anywhere between the affected driver(s) and the amp. I use them for tweeters simply for protection (way out of the passband) and install them at the amp since they're kinda big (100 uF). How? Splice the wire to the tweeter wire using solder or a crimp connection. This way I wind up putting one of the cap leads directly into one of the amp's outputs. It doesn't matter which end of the wire as this in an AC circuit but you wanna make sure to buy non-polarized caps. Electrolytic is fine.
  2. Feb 10, 2019 at 7:32 AM
    #42
    override
    override Well-Known Member
    Robert
    2015 DC Tacoma Sport 4x4
    Glad I saw this thread, I have been installing my system over the past month here and there when I get the chance to work on it and I've been wanting a full range to go with my component set. Considered A-Pillar pods but has to be custom, with this I can move the tweet to the sail panel and stick my 3.5 in the door! Thanks for the idea :cheers:
  3. Feb 10, 2019 at 8:00 AM
    #43
    Sandrail
    Sandrail Member
    Paul
    San Antonio
    08 Tacoma 4dr 4wd
    3inch lift winch mount spot lights bed mounted spare roof rack lt285 75r r16 tires cb radio
    To third I did not use a capacitor I just used connectors so I could still use the factory connections.
  4. Feb 10, 2019 at 2:54 PM
    #44
    PETEREDGE
    PETEREDGE [OP] Well-Known Member
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    ARB FRONT BUMPER...16x8 SR8 RIMS ,YOKAHAMA MT'S,DEMELLO SLIDERS,UPGRADED SOUND SYSTEM...
    It filters out certain bass frequencies so you get no distortion .
    tbird95[QUOTED] likes this.
  5. Feb 10, 2019 at 9:24 PM
    #45
    tbird95
    tbird95 Well-Known Member
    British Columbia, Canada
    TRD sport SR5 V6 DC, LB, 4x4, Tow package
    4runner heated, signal, courtesy light side mirrors, rearview mirror w/compass, temp & backup cam w/ pop luck PL 5400, Interior lights/gauges, BHLM, grillcraft MX black. Third brake light LED swap, rear tail lights LED swap from 2011. 3" Toytec (Boss) Coil overs, rear TSB AAL Bilsteins, Light Racing UCA. TRD grill badge, VIPER Smart Start.
    Great thanks and its required or not for adding 3.5" in place of the tweeters?
  6. Feb 10, 2019 at 11:36 PM
    #46
    tbird95
    Awesome, thanks. And any idea what type or size would be needed?
  7. Feb 11, 2019 at 7:25 PM
    #47
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    Not required but depends on sound your looking for.
