Added a new leaf to my 3 pack rear springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Peru, Feb 9, 2012.
  1. Feb 9, 2012 at 6:31 PM
    Peru
    Peru [OP] Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    Got fed up with the repair toyota provided and went ahaid and added a new leaf to the pack -- what a difference. 4 leaf spring pack is definitly the way to go. Its similar to what the hilux uses.
    That begs the question how could toyota commit such an error? Ive seen so many complaints and after bottoming out so many times i went with the TSB which only marginally fixed the problem.
    Ill post some pictures and some observations.
  2. May 29, 2012 at 3:16 PM
    JUJtacoma2010
    JUJtacoma2010 Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    can you please put some pictures of the springs itself
  3. May 29, 2012 at 5:19 PM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    Couple of concerns here;
    1) TSB pack is FOUR leaf, not three. That means that the dealer who did the TSB for you RIPPED YOU OFF.
    2) add-a-leaf springs are typically short. If you have just a 3-pack and an add-a-leaf, you may observe the remaining original leaves folding backwards beyond the add-a-leaf eventually.
