Added Blocks in Rear...Grinding Noise in Rear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1BlkT, May 25, 2010.
  1. May 25, 2010 at 7:32 PM
    1BlkT
    1BlkT [OP] Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    My brother has an 06 with spindles and coilovers up front for about 6.5 inches of lift. In the rear he has a Deaver 12 Pack but it has since settled so today he added 1.5'' blocks. It sits nice and level and it's only going to see the pavement so he didn't mind adding the blocks.
    The problem though is after installing them whenever he brakes somewhat hard there is a grinding sound. It's not the brakes since those have recently been replaced. However you know that sound when you are wearing into your rotors, well it sounds like that almost, more so from the center of the truck. Could it have to do with the driveshaft? There aren't any wobbles though.
    Any ideas?
  2. May 25, 2010 at 7:35 PM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    Boulder Creek, CA (Nor-Cal)
    2010 SSM DCLB
    Is it in the towards the front or back? Is it like a high screeching noise?
  3. May 25, 2010 at 7:42 PM
    1BlkT
    Ty
    90603
    It's like right under the cab where the truck bed begins and its like a low grinding that last for about 2 secs as you brake hard.
  4. May 25, 2010 at 7:48 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    angle of driveline and noise from carrier bearing? my guess
  5. May 25, 2010 at 7:52 PM
    jacob_wood
    Jacob
    2010 SSM DCLB
    That was gonna be my guess. I never had that though when I had that much lift in front, but then again my rear was stock hah.
  6. May 25, 2010 at 7:58 PM
    THROUGHITALLDUDE
    THROUGHITALLDUDE Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    i have a buddy of mine who owns his own shop and he owns a tacoma and he said whenever your lifting the rear over 2.5'' angles on the drive shaft can alot of wear and tear and make weird noises i would look into somehow straightening that angle out a little more now that its lifted alot higher
  7. May 26, 2010 at 9:27 AM
    1BlkT
    Ty
    90603
    Ya I was thinking it was from the angle of the drive shaft as well.
    Update: He drove it around a couple miles today and there is a noticeable vibe.
    I think he might just take the blocks off and lower the front a little bit if he can't figure out how to fix this.
  8. May 27, 2010 at 3:22 PM
    1BlkT
    Ty
    90603
    Blocks removed grind & vibe gone as well :cool:
  9. May 27, 2010 at 5:23 PM
    MachoTaco10
    MachoTaco10 Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    buy tapered rear blocks for a better driveline angle. common problem on jeeps
