Added MT90 Fluid, Now 3rd Gear Grinds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joelmiller285, Oct 16, 2018.
  1. Oct 31, 2018 at 10:57 AM
    #41
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It’s same as you, only when it’s first warming up and I also run redline mt90. I just make sure to shift slowly into third
  2. Oct 31, 2018 at 10:25 PM
    #42
    joes06tacoma
    Joe
    Central Coast, CA
    It's not likely anything will fail to the point of not being driveable.
    Had a company truck (Ford Ranger) that had 150K on it when I got it and ground when shifting from 2nd to 3rd. I drove it for 30K or so with no change. I would hesitate a half second between gears and it wouldn't grind that way. Last I heard that vehicle had 280K on it and was still running with same transmission.
    whatstcp likes this.
  3. Nov 2, 2018 at 1:03 PM
    #43
    96carboard
    96carboard Well-Known Member
    This is the chart that you are looking for;
    Now granted, that is PROBABLY part of one of those incredibly long AMSOIL advertisements, but I think it at least gives you a good picture that some gear oil is simply TOO THICK when it is cold.
    I've never actually tried any of those oils listed as "FAIL", but I can clearly tell the difference even between two of them that are relatively close.
    I *once* tried putting in mobile 1, and notch-notch-grind-grind. It was fine when I put it in while on vacation in a warm place. Drove back up to the January cold and it was absolutely terrible. I did the oil change while on vacation specifically so I wouldn't have to do it in the cold, unfortunately, it didn't work out that way. So I switched it out for AMSOIL, and no more notches or grinds.
    And funny thing is that based on that chart, mobile is the second best. Well, I guess that second best just isn't good enough.
  4. Nov 22, 2018 at 8:21 AM
    #44
    joelmiller285
    joelmiller285 [OP] Member
    Joel
    2006 Tacoma V6, 6 Speed, 4X4
    Update:
    Tried the magical Ford fluid and I think it's worse than it was with the MT90. The best so far has been the 75/25 ratio of MT90 and MTL. I'm going to try using MT85. If that doesn't work I'll just go back to MT90 and accept my fate.
  5. Nov 22, 2018 at 5:25 PM
    #45
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Thanks for the update at least. Much appreciated.
  6. Jan 12, 2021 at 5:30 PM
    #46
    97duc748
    97duc748 Well-Known Member
    07 Tacoma
    Snugtop, lift, Prinsu Rack and lead foot.
    I have the exact same problem. I had the transmission oil in my 2007 changed at 195k and now when shifting into 3rd. I am putting in GL4 Now after the GL-5 was not working well. If this doesn’t work i will go back to the toyota factory stuff
  7. Jan 12, 2021 at 6:09 PM
    #47
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I've never used Redline but have had good luck with Lucas and Royal Purple. I'm not a big believer in the snake oil claims of some of the boutique oils, but RP really did work well.
    I've had my truck since it had just under 12,000 miles on it. I'm at 107,000 now and it sometimes grinds a little when shifting into 3rd. I think it's been about the same since I got it. Just don't force it.
  8. Jan 13, 2021 at 11:46 AM
    #48
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Redline is definitely not snake oil, it's a POA group V top of the line synthetic used by tens thousands of owners both car and truck. That being said, Walmart Supertech synthetic is widely available, cheap and has great reviews even with their gear oil.
    Junkhead and whatstcp like this.
  9. Jan 13, 2021 at 4:51 PM
    #49
    winkel
    Corydon, IN
    My snake oil comment was directed at Royal Purple. BUT it actually made my transmission smoother. You'll want to make sure you stay with a GL4 flavor for the transmission.
    Grossomotto[QUOTED] likes this.
  10. Mar 27, 2021 at 10:54 PM
    #50
    TacoTuesday1
    FL
    I wonder why people run full MT90
    instead of half and half
    or straight 100% MTL, which is thinner. Thinner usually means better shift and cold shift performance
    while still being thick enough to withstand the stress
    not like it's dropping down to being a 5w30 motor oil
    nv529 and Grossomotto[QUOTED] like this.
  11. Jul 14, 2021 at 10:09 AM
    #51
    Joeyourbro
    Joeyourbro Well-Known Member
    Joe
    Vegas
    2015 2.7 5MT
    I just put this stuff in my 2.7 5 speed before reading this thread. I have to say the shifts feel smoother, but the acceleration seems a tad bit slower after releasing the clutch. RPMs seem to drop lower between shifts. Not sure if that’s because it’s thicker and the fact that I was a 1/4” off level with the front end being higher than the rear, so it was ever so slightly overfilled I guess. Either way my shifts feel smoother. Gonna have to try and shift faster as I got accustomed to shifting slower with the factory oil. Wonder how this is gonna hold up in the 20 degree weather we get here in the winter.
  12. Jul 14, 2021 at 6:28 PM
    #52
    tube
    tube Member
    So I hear nothing but positive traits about mt90, put it in my ‘09 6spd, then read this thread… lol
    haven’t noticed any huge differences, shifts do seem a bit notchier which I like a lot, coming from an e39 m5 I’ll take any precision on this truck I can get lol
  13. Jul 23, 2021 at 5:21 PM
    #53
    2001 4x4
    2001 4x4 Well-Known Member
    2008 TRD Offroad 6MT
    I just changed out my manual trans fluid on my 2008 with MT-90 and it made the shifts butter smooth! It used to be crunchy going into third...not anymore!
    This is my second manual Tacoma I used MT-90 on with great success.
  14. Jun 15, 2024 at 1:32 PM
    #54
    nv529
    nv529 Well-Known Member
    Nick
    Metro Detroit, Michigan
    2006 Long Travel Taco, 2010 FJC, 2018 F250 Alumiduty
    Hey op, did you ever get this sorted out?
