Added Power in 2nd Generation Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by beeser, Oct 31, 2008.
  1. Oct 31, 2008 at 6:31 PM
    beeser
    beeser [OP] Active Member
    Is it reasonable that the additional 45 hp (and 45 lb. ft. torgue) in a 2nd generation Tacoma (V6) would make a significant difference in towing a 4000 lb. trailer? A fellow RVer has a 2008 Prerunner and is able to maintain 55 mph on the same hills that I'm barely able to keep at 35 mph with my 2004 Prerunner. Both trailers about the same weight give or take 100 lbs.
  2. Oct 31, 2008 at 6:40 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    I think it has to do more with torque rather than HP. I can't recall the torque differences between the 2 gens though.
  3. Oct 31, 2008 at 7:38 PM
    beeser
    The torque difference is about 45 ft. lbs.
  4. Oct 31, 2008 at 7:46 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I owned an 02 prerunner SR5 and now I own an 07 4x4 both DC. My new truck hauls way better, wether it be the added power or difference in weight transferal I don't know but damn. Maybe its not so much the difference in power but where the power band lies on the 2 trucks. Seems Tacomas make power in the higher RPMs.
  5. Nov 1, 2008 at 10:11 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Bingo ...
    220 ft lbs @ 3600 rpm's (2001 - 2004 5VZ)
    versus
    266 ft lbs @ 3800 rpm's (2005+ 1GR)
  6. Nov 1, 2008 at 5:00 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    also is your buddies new one manual or auto? and what rear gears does he have compared to you.. I good drop in gears will make a big difference when pulling a trailer
  7. Nov 1, 2008 at 5:07 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    ^ thats a good point but my 02 prerunner had the v6 with a 3.90 gear and my 07 4x4 has 3.73 and hauls so much better.
  8. Nov 1, 2008 at 8:28 PM
    beeser
    As luk8272 stated, my '04 has a 3.91 final gear ratio and my friend's is 3.73. The advantage in towing goes to my '04 if I'm not mistaken.
  9. Nov 2, 2008 at 12:20 AM
    350TacoZilla
    Hancock MD
    yeah for gearing it would go to you slightly auto or manual between both trucks? for little increase you could drop gears to either 4.10 or 4.30 both came factory in tacomas so they arent too deep for factory sized tires or anything.. there are alot of possibilities to his better hill climbing... both trucks similar trim? like extra cab's or is one reg and one extra/dc.... if your truck was mine and I towed that same amount alot I would probably drop the gears to the 4.30s.. and if you dont already I would add a free flowing exhaust and intake...or the flip side would be if you have the money... go with a trd supercharger...set of headers and custom exhaust.. you will be over his HP and TQ and already have better gears
