Adding 3rd driving light question
Discussion in 'Lighting' started by mcdowell, Mar 18, 2012.
  1. Mar 18, 2012 at 7:54 AM
    mcdowell
    mcdowell [OP] My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Adding 3rd driving light between the two existing. Can i tap it into one of the existing lights wires without causing problems? KC 130w.
  2. Mar 18, 2012 at 9:09 AM
    joes06tacoma
    Joe
    Central Coast, CA
    130W lights draw around 11 amps each. The wiring kit you have likely has a 30Amp relay and wiring to support 25 Amps. You'd likely blow the fuse. Upsizing the fuse is dangerous since it's there to protect the wiring and it's sized for that size wire.
    I would leave what you have in place. Add a second fuse and relay coming directly off the battery and use that to provide power to the new light. You can tap the existing light circuit to trigger the new relay and have all your lights on the same switch that way.
  3. Mar 18, 2012 at 9:36 AM
    mcdowell
    mike
    mobile al
    2011 prerunner SR5
    Thanks for the detail. I appreciate it
