Adding 4:56 Gears to 2016 TRD Sport??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cruzcampo, Mar 21, 2016.
  1. Mar 21, 2016 at 2:29 PM
    Cruzcampo
    Cruzcampo [OP] Well-Known Member
    What are your thoughts on adding a different set of gears to help the little Taco motor/trans out while running bigger tires (285/70/17)?? Just exploring ideas/options...
    Thanks
  2. Mar 21, 2016 at 4:23 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    IMO the tires that it comes with are too big with the way it is geared. go bigger and yea re-gear or you will never use 6th gear. i was going up a slight incline maybe 5% in 5th gear at 45mph. holding steady on the gas pedal the truck started to slow down enough i had to down shift to 4th still holding the gas steady and then it speed-ed up. stock it act's like my old 4.0 jeep that i put 33" tires on after that i never used 5th gear. last, the incline i described above i drive daily and in my 2008 tacoma 4.0 never had that issue.
  3. Mar 21, 2016 at 7:24 PM
    Cruzcampo
    Yah that's my thoughts too...its just the cost of it all...the off road shop quoted me with a air locker up front $4500 installed...that seems way way out to me, but, I could be wrong...need to check around!
  4. Mar 21, 2016 at 8:22 PM
    Ocean82
    Ocean82 Member
    Any time you increase tire size, you need to adjust your final drive ratio to account for the difference.
  5. Mar 21, 2016 at 8:29 PM
    psc199333
    psc199333 Well-Known Member
    Phillip
    2016 Trd off road
    With that size, and how tall 6th is on the auto, I wouldn't be afraid of 4.88 either.
  6. Mar 21, 2016 at 9:11 PM
    Cruzcampo
    I thought about the 4:88 and that may be an option for sure!
    psc199333 likes this.
  7. Mar 21, 2016 at 10:27 PM
    Chris.taco.2016
    Chris.taco.2016 Well-Known Member
    2016 Tacoma trd sport mgm dclb
    This would be amazing if it wasn't so damn expensive
  8. Mar 21, 2016 at 11:07 PM
    psc199333
    Phillip
    2016 Trd off road
    You can always just do the back and make sure you keep it in 2wd and see if you like them on the street.
  9. Mar 21, 2016 at 11:11 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    there is no 4.88 gears for the front clamshell. And at 4500 i hope that shop provides the lube, cuz they are bending you over pretty hard. should be less than half that cost.
  10. Mar 21, 2016 at 11:14 PM
    psc199333
    Phillip
    2016 Trd off road
  11. Mar 22, 2016 at 8:05 AM
    hobbittech
    hobbittech Active Member
    Micahel
    Tempe, AZ
    2016 Tacoma 3.5L 4X4 TRD OR
    Icon stage 7 suspenion, icon rear hydraulic bump stops, 17" Method standard race wheels, Toyo mud terrian 285 75 17, coil bucket gussets, cam tab gussets, spindle gussets, ARB air compressor, 2 A-pillar mounted baja designs XL80 lights.
    I have 285 75 17s and am thinking about regearing as well.
  12. Mar 22, 2016 at 11:20 AM
    PSU Taco85
    optional
  13. Mar 22, 2016 at 6:28 PM
    Cruzcampo
    Here is the breakdown of the estimate that I got...It seems high!! If someone could take a look that has had this done and advise what on here is overkill please let me know.
    Thanks
    Date Estimate: 3/21/2016
    Estimate #95965
    Name / Address
    Ship To
    Retail in WA State
    J.T.'s Parts & Accessories
    5980 Goodwin Rd
    Cashmere, WA 98815
    Rep JM P.O. No.
    509-888-2953
    Total
    Subtotal
    Sales Tax (8.2%)
    Customer E-mail Customer Phone
    shipping@justdifferentials....
    Item Description Qty Cost Weight Total
    2016 Taco needs ARB locker, no eloc, auto trans
    ARBRD121 Toyota 8" Reverse IFS Short Clamshell 3.73 & Down +Thick Gears 30 Sp1 $940.50 25
    ARBCKMA12 ARB 12 Volt High Output Compressor Kit, (Rec. ARBPUKT) 1 $275.50
    ARBPUKT PUMP UP KIT FOR USE WITH ARB AIR COMPRESSOR1 $35.00
    T8S-456RT-NG Toyota 8" IFS Clamshell 4.56 R&P, Thick, (fits 3.73 & Down Carrier or RD121) 1 $299.99
    MKT8S-R Toyota 8" Reverse Clamshell Master Install Kit (Incl Side Shims) 1 $357.00
    TV6-456-29-NG TOY 8" 4.56 R&P ALSO TACOMA W/LOCKER HD 29 SPL V6 (02 & OLDER REQ. YOKTOYFITKIT-29) 1 $219.99
    MKTV6-B Master Kit, Toyota 8" V6, T4, & Rev, use w/29 Spl 1 $260.00
    Labor Hourly Shop Labor Rate for gears and locker 13.5 $85.00 Total $1,147.50
    Labor Hourly Shop Labor Rate 5 $85.00 $425.00 (Compressor Install)
    LUBE 85W140 BULK GEAR OIL GL5 5 12.00 50.00 60.00T
    Waste Waste Oil Disposal/Shop Consumable 1 $10.00
    NC-T8S-3 T8S, Bare Std Case 3.73 & down (Clamshell Style) 1.625" Deck Hgt Also fits T8S-XXXRT-NG (OE Take-out) $365.00
    $4,755.91 Total w tax
  14. Mar 22, 2016 at 6:43 PM
    PSU Taco85
    optional
    Looks like you are paying for the clamshell due to the carrier break, which seems strange if they are using thick cut gears. There's $365 saved. And also 5 hours to install a compressor, you might as well do that yourself, theres another 425 back. 13.5 hours of labor seems about right for setting up the gears
    A front clamshell with an ARB from ECGS is 1475
    Rear 8.4" regeared is 675.
    Assuming you buy your own compressor or add the cost of 275 in for it that brings the total to 2425. I would just do that and install yourself, save the other 2 grand for the beer.
  15. Mar 22, 2016 at 7:01 PM
    Cruzcampo
    Hahaa!!! I like the way you think!!
  16. Mar 22, 2016 at 8:52 PM
    PSU Taco85
    optional
    yeah you can buy a lot of beer and pizza with the leftover money or hell maybe even get some bigger tires. Seems crazy to pay someone that much labor but that's just me lol
