Adding 8" Wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joe6v6, Jul 28, 2023.
  1. Jul 28, 2023 at 12:41 PM
    Joe6v6
    Joe6v6 [OP] New Member
    Joe
    2023 Tacoma Access Cab
    On a stock 2023 SR Access Cab with the stock steel wheels, im looking to switch to Aluminum rims and install the stock tires - upgrade the tires later - , the stock tires are 245 75 R16 on 7" Steel rims. Would the following size & offset be correct? From what ive seen thee 245's belong on 8" rims anyway. . Thanks & any help is appreciated ;
    • Size: 16x8 | Bolt Pattern: 6x5.5 | Offset: 0mm | Center Bore: 110.1mm | Backspacing: 4.5''
