Adding 881's to Bilstein 5100's or DT Header?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaGus, Feb 21, 2011.
OME 881's or DT Header
Poll closed Mar 23, 2011.
  1. Coils
    10 vote(s)
    83.3%
  2. Header
    2 vote(s)
    16.7%
  1. Feb 21, 2011 at 3:27 PM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    I already have Bilstein 5100's on all 4 corners of the truck and they do ride pretty good, but still a little rough on these WV roads (country roads is an understatement). I'm just wondering whether adding the OME 881 coils and setting the 5100's back to 0 will give me an improved ride quality that is worth the cost of the new coils and installation? I'm just looking for a softer ride, the billys are currently at about 2" of lift and thats all i need.
    On the other hand, i have seen good dyno sheets of the DT header that LCE sells (dual cat w/EGR)
    Its either a DT header or these coils, just looking for the better buy.
  2. Feb 21, 2011 at 9:41 PM
    TacomaGus
    Gus
    Morgantown, WV
  3. Feb 21, 2011 at 10:56 PM
    Pingo
    Pingo Well-Known Member
    North Pole, AK
    2014 S/C TRD Offroad A/C
    My opinion is definitely the 881's... I don't know for a fact but from what I've read you'll have a better ride with the billys at 0... But either way you won't get a better ride if you keep it the way it is and get the header. It really boils down to whether you prefer a suspension upgrade or performance.
  4. Feb 22, 2011 at 12:30 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    add the coils and install them yourself.
    not a bad project if you have a friend to help :D
  5. Feb 22, 2011 at 8:32 AM
    TacomaGus
    Gus
    Morgantown, WV
    see i'm torn, b/c they will end up costing close to the same amount and i would like a better ride, but also this particular header has shown great gains. I know the header will obviously make a difference, i'm just wondering how much the coils will improve the ride over my current set up. It'd be perfect if there was someone on here who just had the 5100's and then put on the 881's
  6. Feb 22, 2011 at 9:46 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Id go with the headers.
  7. Feb 22, 2011 at 11:23 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    A pair of coils is only 160...
  8. Feb 22, 2011 at 4:41 PM
    TacomaGus
    Gus
    Morgantown, WV
    true that, i was looking at the wrong thing on wheelers haha. Do you have to take apart the whole upper strut assembly to put in the new coils? I'm asking b/c this summer i wanted to put a small spacer in to level out the taco lean, but the guy i go to said he wouldn't be able to get the strut assembly bolts off to put in the spacer with longer bolts since the stock ones had rusted so much
  9. Feb 22, 2011 at 4:48 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Damn rusted bolts...
    well you could try soaking them in like pb blaster or something to get them off, but yes you would need to take the whole thing
    off, if you don't want to assemble the coils to the shock then just have wheelers do it for sixty,
    but if they assemble it replacing them will be super easy.
    Or you could assemble them yourself, with a rented spring compressor it will take a lil longer. :cool:
  10. Feb 22, 2011 at 5:54 PM
    TacomaGus
    Gus
    Morgantown, WV
    well i want to keep the 5100's that i already have to avoid another set of shocks when all i need is the coils
  11. Feb 22, 2011 at 6:59 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Then just do the second option.
    Buy the coils, take the old ones of you current 5100's and put the OME coils back on :D and renting a compressor from autozone turns out to be free.
    give them 50$ up front and then keep it for up to 3 months
    and on return get 100% back!!
  12. Feb 22, 2011 at 7:07 PM
    TacomaGus
    Gus
    Morgantown, WV
    thanks for all the advice man. I emailed wheelers with a bunch of questions about the coils and the ride. Tacomaman06 had the same setup as i did (billy's at highest setting) and then put on the OME 881's and said the ride is too rough for certain roads. I'm looking for smoother not rougher so i'm still debating
  13. Feb 22, 2011 at 7:16 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    You'll like the 881s over your stock coils you just have to let them settle. I say go both though. Save up some because both would be nice additions, just do coils first
  14. Feb 22, 2011 at 7:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i'd go on with the header.
    im not real crazy bout the 5100's coupled with the 881 coils.
  15. Feb 22, 2011 at 7:23 PM
    TacomaGus
    Gus
    Morgantown, WV
    ya all i need is 2" of lift so the 881's should do it. I've just heard from some people that the 881's are still a little stiff and too stiff for the 5100's. The ride with the 5100's is fine on the highway and over large bumps, but i'm looking for a smoother ride on city/country roads with potholes, cracks, etc. as thats where the ride is stiff now and from some reviews, is really stiff with the 881's. Idk, i just can't see how the 881's with the 5100's not loaded down, wouldn't be an improvement over a loaded shock and 160k mile old coils
  16. Feb 22, 2011 at 7:24 PM
    Pingo
    North Pole, AK
    Why aren't you real crazy about the set up? Seems like a lot of people run it and are pretty happy with it. Just curious because I also will be shopping for suspension soon.
  17. Feb 22, 2011 at 7:25 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    go for the coils then.......you may like the setup alot better than i do man. you may get 2.5 inches from it tho....seeing as i got 2 inches on my dc v6 when i first put it on. its settled maybe a 1/4 inch in close to 20k.
  18. Feb 22, 2011 at 7:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im just not real crazy about the ride after you put some miles on it. it was sweet at first.......but the 5100's seem to stiffen up the more miles you put on them.
