Adding a 15A circuit
Discussion in 'Audio & Video' started by jimsphoto, Oct 18, 2011.
  1. Oct 18, 2011 at 8:20 PM
    jimsphoto
    jimsphoto [OP] New Member
    louisville
    2011 tacoma sr5
    towing package
    I need to install a 2meter ham radio in my 2011 Tacoma 2wd SR5. Any suggestions?
  2. Oct 19, 2011 at 12:36 AM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    Dunno, just wanted to welcome you, aloha!
  3. Oct 19, 2011 at 8:17 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I know nothing about CB's but if you need a new 15A circuit, you can tap off the fuse box under the hood and use an in-line fuse. If you pop the cover off the under-hood fuse panel, there's a bolt on the passenger side that is always 'hot'. Get a weather proof in-line fuse holder, crimp on a fitting so it slides over the bolt, tighten the nut down and then run the wire into the cab. Put a 15A fuse in the fuse holder and you now have a constant hot, 15A circuit. Oh, it's a good idea to disconnect the batter before messing with that bolt!
    If you want a circuit that is only on when the truck is on, you can use a relay. Let me know if you want to go this route and I can tell you how to do that also.
    Lastly, Welcome to TW!
  4. Oct 19, 2011 at 8:24 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
  5. Oct 19, 2011 at 1:48 PM
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    Run your power for the radio from the battery. You'll get the cleanest power and are able to run the correct sized cables that way.
    I used #6 to supply my rear fuse panel that powers my icom.
    Welcome to TW!
  6. Oct 19, 2011 at 1:53 PM
    Pugga
    Massachusetts
    Fused power from the battery if you're so inclined... FWIW, that bolt I mentioned above comes directly from the battery but keeps the battery terminals free of excess wires and leads.
  7. Oct 20, 2011 at 2:03 PM
    RevAdam
    Adam
    Upstate SC
    11 TRD OR 4x4
    I take for granted people are intelligent enough to fuse within 8" of the battery or before passing through anything that can chafe the wire.
    Thanks for the catch!
