Adding a capacitor to a fuse for initial loading?
Discussion in 'Off-Topic Discussion' started by soggyBottom, May 19, 2023.
  1. May 19, 2023 at 5:49 AM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    I have a device that "can" run on 12v. When I plug it in to my cigarette lighter it blows 15A fuses. The device works fine on a big 40v power supply.
    The device is rated for 500w output, but I'm only ever really using about 100watts. it's just the initial moment when it's plugged in that the current draw is too high.
    I've seen electronics use a ceramic capacitors across a fuse and I'm wondering if I could do something like that here. Any ideas on where to start? I have a lot of electrolytic and ceramic caps.
  2. May 19, 2023 at 6:04 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
  3. May 19, 2023 at 6:12 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    The point of fusing is to protect components of the system, ie the wiring, wire terminals, etc. If you are going to the length of modifying the factory system, Id just run a dedicated heavy gauge lead from the battery.
    Also I have the same question as above, what is this device? It operates at both 12v and 40v?
    Bivouac likes this.
  4. May 19, 2023 at 11:33 AM
    soggyBottom
    This is it. It's actually a 500w LiPo charger. It has 2 inputs.
    1) 120vAC - 40vDC - charger
    2) DC input with barrel and xt60 in parallel
  5. May 19, 2023 at 11:36 AM
    soggyBottom
    I misspoke slightly. It accepts a DC input between 10v and 38v. I have my 40v DC power supply turned down to 38v.
  6. May 19, 2023 at 11:42 AM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    I’m not an EE. Now that’s out of the way..
    I would think the capacitor would go in series just after the fuse to reduce the initial current surge through the fuse. Also consider it will still be live for a while after pulling the fuse (or blowing a fuse) unless you add some high resistance jumper.
    edit: Actually even if only using 100W it is a decent amount for the cigarette lighter. As suggested earlier you’re probably better off running a connection to the battery. 12ga wire should be good for a 25amp fuse and maybe then you can skip the capacitor. That would still be undersized if you used the full device capacity.
  7. May 19, 2023 at 11:47 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    How big of a current spike are we talking here? Is it just charging up some big capacitors?
    A thermistor or resistor would be a better choice to limit the inrush current.
    Bivouac likes this.
  8. May 19, 2023 at 12:36 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Run a new circuit from the battery for the load you have and be done.
    Do you plan to add a timer to allow the cap to charge first before your device is energized .
    Your just adding even more of a demand on your circuit .
    It is your project do what you think best.
    SR-71A likes this.
