Adding a Clutch Start Cancel Button
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bovaloe, Feb 3, 2021.
  1. Feb 28, 2023 at 12:28 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    pin 2 is the start fuse which is only hot with the ignition in the start position.
    daveeasa[QUOTED] likes this.
  2. May 4, 2023 at 9:19 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
  3. May 4, 2023 at 10:49 AM
    BossFan
    BossFan Well-Known Member
    Frank
    NJ
    03 TRD 4x4 X-Cab MT swap
    Tundra brakes Bilstein 5100s OME springs
    Here they are. I’m just learning about this myself as I convert my automatic to a 5-speed.
  4. May 4, 2023 at 11:14 AM
    daveeasa
    David
    PNW
    And, just for completeness, the top left one is for cruise cancel (when open), bottom right one is for start cancel (when open).
    Jeff Lange likes this.
  5. May 4, 2023 at 4:00 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    90980-10824 is the male connector to plug into the harness at the clutch switch
    90980-10825 is the female connector to plug into the clutch switch
    Jeff
    daveeasa likes this.
  6. May 5, 2023 at 10:06 AM
    daveeasa
    David
    PNW
    OK, putting it all together now.
    I have unused connectors which I believe to be for Auto LSD / traction control (84988) and fog (84162).
    I have CSC C7 switch and pigtail with the following needs:
    1. White w black stripe == chassis ground -> to factory ground point or steal from one of the switch plugs below.
    2. Purple == This is the + side of the clutch start switch, C8 from the diagram above I'm not sure if I should place a diode inline off this lead but I think that would be smart, would mate to the blue
    3. Green == fused ignition power -> either add a fuse or steal from one of the switch plugs below.
    4. Black w yellow stripe == This is the - side of the clutch start switch, tie directly to the clutch start switch C8, should match color.
    I'm sure both of these already have grounds so it's mostly a matter of if they have ignition power. I'd bet 84988 would have that and it'd work OK for this.
    Then a Y at the clutch switch itself where I'll tie in purple and black w/yellow.
    I'm guessing a 1 amp diode is adequate here.
  7. May 19, 2023 at 4:57 PM
    daveeasa
    David
    PNW
    More recon today. Pins 1 and 4 on VSC go hot with ignition. Anyone got the pinout for me? @Jeff Lange or @caribe makaira maybe?
    The fog connector has a ground and parking lights plus what I assume are fog out and dash illumination.
  8. May 19, 2023 at 5:52 PM
    caribe makaira
    Caribbean, Puerto Rico
    It's NOT the VSC connector...
  9. May 19, 2023 at 5:58 PM
    caribe makaira
  10. May 19, 2023 at 7:47 PM
    daveeasa
    David
    PNW
    Ah, it’s the stock inverter? My bad. Thanks.
  11. May 19, 2023 at 7:49 PM
    caribe makaira
    :cheers:
  12. May 19, 2023 at 8:11 PM
    daveeasa
    David
    PNW
    Any chance you know the terminal type for these? Fog looks like 090IIU or 090U to me. Haven’t opened the inverter one.
    Does pin 4 redirected to clutch start cancel for ignition switched power seem ok? No grounds in that inverter switch I take it?
  13. May 19, 2023 at 8:17 PM
    caribe makaira
    090IIU all
    No grounds on inverter switch connector...
  14. Jun 26, 2023 at 3:15 PM
    daveeasa
    David
    PNW
    Just got this installed and working, thanks everyone for the help.
    In summary:
    The CSC switch has 4 positions. Power in, power out, chassis ground and clutch switch ground output. Power in I used lt green, power out purple though at the switch it is blue. Chassis ground always white w black stripe and clutch switch ground is black w yellow, I got lazy and used solid black. 12-18” is plenty for the CSC switch to clutch switch run.
    Tie chassis ground to the Auto LSD chassis ground, white w black stripe.
    Tie power in to the Inverter power in, light green, position 4
    Tie clutch start cancel power out to clutch switch power in, blue on the clutch switch side, purple on the clutch start cancel side.
    Tie clutch start cancel ground out to clutch switch ground, black w yellow for both.
    no diodes needed. Granted since I don’t have the factory inverter I’m playing loose and fast by stealing the unused switch connector for power. But this is all signal level stuff so presumably safe.
    I made a harness with matching terminals and T’s then de-pinned + repinned but I think 4 positaps make a ton more sense. Or even T taps really, then if your clutch start cancel pigtail needs longer purple and black w yellow you extend those with 22 gauge wire to reach the clutch switch.
    Noercarr likes this.
