adding a coil over lift. need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by houndsmen, Nov 24, 2009.
  1. Nov 24, 2009 at 3:41 PM
    houndsmen
    houndsmen [OP] Well-Known Member
    hey guys i have a 2.5 spacer leveling kit right now on my 01 tacoma and i have been seeing a lot of guys out there adding a 1" coil over system in the front. does anyone have an opinion on this? i am going to do this once i get a little more details. thanx for the help
  2. Nov 24, 2009 at 5:12 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The most you can safely(as far as excessive wear and tear on other parts) lift a 4x4 is 3". The description you gave is a little vague. You can get rid of your current setup though and go with a much better Coilover. Much better ride and perfomance but also alot more money.
  3. Nov 25, 2009 at 8:07 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Stacking suspension lift is a no no. You can keep the 2.5" and do a 1" BL or a 3" suspension lift or a drop bracket kit.
  4. Nov 25, 2009 at 9:24 AM
    houndsmen
    would just adding a coilover lift be higher than my leveling kit now?
  5. Nov 25, 2009 at 10:44 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    if you took off your leveling kit and put on the coilovers it could be higher. they are usually adjustable. i did the same thing and its night and day. do it up
