Adding a Heavy Plate Bumper?
Discussion in 'Suspension' started by AEmedic, Nov 24, 2013.
  1. Nov 24, 2013 at 11:29 AM
    AEmedic
    AEmedic [OP] Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
    Okay, I am adding a heavy plate bumper (145 ish lbs) on the front of my 14 Sport DCLB.
    All I want to do is preserve the ride and alignment near stock capability and feel.
    What, if anything, should I change?
  2. Nov 24, 2013 at 11:33 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    All your front suspension with stock shocks it will be really spongy.
  3. Nov 24, 2013 at 11:47 AM
    AEmedic
    Boise, ID
    What needs to be upgraded to compensate for the added weight?
  4. Nov 25, 2013 at 12:19 PM
    AEmedic
    Boise, ID
    Look guys, I'm fairly novice when it comes to the suspension on our trucks and I need your help.
    Thanks to JLee I know that the front suspension is going to be a bit jacked up, but no one has offered the best means of counteracting the additional weight.
    I will be using the truck for light off road, but nothing more interesting than light trails to get the bikes places to ride.
    So, I'd like to properly support the weight, I might entertain a slight lift in the future but nothing more than a few inches and I'd like to do everything right, nothing half-assed.
    Suggestions?
  5. Nov 25, 2013 at 12:20 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    What is your budget?
  6. Nov 25, 2013 at 12:29 PM
    AEmedic
    Boise, ID
    Honestly I don't have a budget...
    I made a choice to get this bumper and now I NEED to support it.
    I'd rather not do a full up lift right now because that would require wheels and tires and lots of ancillary items.
    If what I can buy sets me up for future suspension upgrades that great!
    If possible I'd like to go mostly plug and play mods, no cutting or fabrication, just bolt on...
  7. Nov 25, 2013 at 12:31 PM
    Boone
    Boone, NC
    Airbags deployed
    I'd just go for some Bilstein 5100's set @ 0 and OME 886 coils. Or OME Nitrochargers with the 886's.
    Didn't read the not wanting to lift part. vvvvv Pugga's suggestion sounds better in that case.
  8. Nov 25, 2013 at 12:31 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Keeping everything at stock height is the clincher. This site is pretty well versed in getting 3" of lift with that kind of weight hanging off the front end but staying at stock height while beefing up the front isn't overly common and can become a bit of a guessing game unless you go with a fully adjustable coilover.
    If you went with something like OME 884's, they provide 2" of lift on an unloaded Tacoma, throw 145lbs up front and you might settle down to 1" of lift or less. Same with Eibach coils, they lift 1.5" but are stiffer than 884's so they might sag less. It becomes a little bit of a guessing game.
    Your other option is get to get a set of fully adjustable coilovers with a stiffer spring. This would provide you the best ride and the threaded collar would give you the the adjustability to set the ride height where you want it. Talk to someone like Downsouth Motorsports or SDHQ, they might be able to give you some more options or ideas.
  9. Nov 25, 2013 at 12:32 PM
    Pugga
    Massachusetts
    Not for stock height... That combo, even with the bumper, will give him at least 2" of lift if not more.
  10. Nov 25, 2013 at 12:33 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    You can get replacement coilovers like fox, icon, kings, etc.. and set them so they effectively have "0" lift with the weight of the bumper. You will need higher spring rate springs to support the extra weight along with shocks valved for this application as well
  11. Nov 25, 2013 at 12:34 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    ^what this guy said. I bet eibach coils with 5100s set at 0 would be a good choice.
  12. Nov 25, 2013 at 12:42 PM
    WLFFGreg
    WLFFGreg Well-Known Member
    Greg
    Northern NH
    TRD Sport
    Bent stock IFS skid
    I second the OME with 884's, once you are ready to lift it's as simple as changing the springs. You can also do the 5100's that were mentioned, but a softer spring I would think.
    If you maintain stock ride height/rake, 3 months down the road will you be happy or will you be looking to then do a 2-3" lift? Consider your goals over the next year, a project like this that requires you to take apart the front suspension isn't worth repeating again a few months down the road.
    I'd suggest either waiting to instal the bumper until you have some tires lined up, or doing the small 2-3" lift and leaving it on stock tires - it doesn't look bad, and there is a thread around here that shows exactly that. Save yourself the headache (or money) from having to pull apart the front suspension a couple months down the road.
    The suspension won't cost any more either to tackle the small lift (when you consider what you need to maintain stock height) - just use caution as when you approach 3", some have trouble getting an alignment (which then brings on the need for new UCA's).
    Greg
  13. Nov 25, 2013 at 12:42 PM
    AEmedic
    Boise, ID
    This is good stuff! I like the idea of the fully adjustable coil overs, especially if that supports any future upgrades. Well, I like them in theory anyway...
  14. Nov 25, 2013 at 12:44 PM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    this. go 5100's and 884's and it'll be at stock height again
  15. Nov 25, 2013 at 4:13 PM
    AEmedic
    Boise, ID
    I did some checking, $1300ish for the adjustable King coil-overs is the way I'd like to go but that will have to wait...
    The guys at Downsouth think I could get away without doing anything for awhile...I still think better safe than sorry.
  16. Nov 25, 2013 at 4:34 PM
    AEmedic
    Boise, ID
    What do you guys think of adjustable ToyTec coil-overs? There is a set local to me...
  17. Nov 26, 2013 at 10:08 AM
    AEmedic
    Boise, ID
    Does anyone have an opinion on the adjustable ToyTec coil-overs?
  18. Nov 26, 2013 at 10:23 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    They are the same thing as 5100s/ eibachs, just with an adjustable collar.
  19. Nov 26, 2013 at 3:13 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    I think 885's would do it. I think the 884's might be too soft with that bumper.
  20. Nov 26, 2013 at 3:15 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I have the adjustable coilovers from toytec with the 5100s on the front. It holds up my bumper and rides nice.
