Adding a Heavy Plate Bumper?
Discussion in 'Suspension' started by AEmedic, Nov 24, 2013.
  1. Nov 26, 2013 at 3:17 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    OME 885x coils, with 5100's at 0 and a 1/4" top plate spacer on the driver's side should level the truck without lifting the rear at all. Learned from experience. About as easy of a bolt-on as you're gonna get, and at a very reasonable budget.
  2. Nov 26, 2013 at 3:19 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    I am running 885s and with my bumper and winch and I am about 1.5" of lift.
  3. Nov 26, 2013 at 3:33 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Billies or coilovers? Are they set to the lowest? That should still level the truck though, but if OP wants to bring the rear up, then a simple AAL would be a cheap easy fix and the total lift of the truck would be less than 2". Enough lift to not need new tires.
  4. Nov 26, 2013 at 3:40 PM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    OME struts. Non adjustable. I have a 1.5" AAL in the rear and with my shell it sits about 3/4" higher in the rear.
  5. Nov 26, 2013 at 5:15 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    X2 my 885s have lost about an inch after a bumper and winch. I vote for eibach coils for the OP, i believe they are shorter than 884s and have a higher spring rate. Less lift and more support for the extra weight. icons or kings would probably be the best option if he is set on stock height.
  6. Nov 26, 2013 at 5:17 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Do not billy 5100s with Eibachs for weight. You will regret it. Like others are saying, go full coilover. You will regret anything much less.
  7. Nov 26, 2013 at 6:05 PM
    AEmedic
    AEmedic [OP] Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
    I appreciate you adding to the discussion, I didn't think I read that others were saying that full coil-overs were the only way to go without regrets.
    Maybe I missed it, is anything other than a full coil-over a waste of time for my application?
  8. Nov 27, 2013 at 6:59 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Others will support the weight, however become stiff. My eibachs sagged after a year.
    Ome or ironman will be your best bet.
    However some full adjustables with appropiate weight rating is what id consider, despite the cost. Do it right the first time.
    Also, after two years, from weight id assume, my billys lower bushings blew.
  9. Nov 27, 2013 at 1:23 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Don't listen to him. He's the guy who almost totaled his truck going through a rain puddle.
  10. Nov 29, 2013 at 9:30 AM
    AEmedic
    Boise, ID
    I'm having a hard time deciding if I can be happy with the ToyTec adjustable coil-overs with the silver Eibach springs . The used set that is local to me and is less than half the cost of a set of Icons as they sit on sale today.
    I'm guessing that the ToyTecs will get me level with no more modifications needed and would work fine but I don't want to hate the ride...obviously I've never ridden in anything other than stock.
  11. Nov 29, 2013 at 11:21 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    I was impressed with icons from the ones I've seen in person. For now run something cheap but just be prepared to upgrade soon.
