Adding a leaf to dakars
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WorKinJoB, Jan 13, 2018.
  1. Jan 13, 2018 at 2:03 PM
    WorKinJoB
    WorKinJoB [OP] Well-Known Member
    Drew
    2017 Tacoma Sport 4x4
    OME lift, 887, Dakar packs 265 70 17 duratracs Snugtop GB sport
    I’m fixing to put a camper top and roof rack to my truck. I have the light dakars And was wondering if anyone has added the OME leaf to it. If so did it come with new u-bolts or did the original u-bolts that come with Dakar’s work. And how was the ride after you added the leaf?. Thanks
  2. Jan 14, 2018 at 10:51 AM
    WorKinJoB
    Drew
    Bueller....Bueller...
  3. Jan 14, 2018 at 10:58 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Sounds like a new question to everyone- try talking with the folks at Headstrong off-road about it, they can answer your question. I put a single leaf on my factory pack and love it - tow 4000 lbs and load up with gear with it just fine.
  4. Jan 14, 2018 at 11:58 AM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
  5. Jan 14, 2018 at 12:34 PM
    Hodakaguy
    Hodakaguy Well-Known Member
    12 Tacoma/Vagabond Drifter
    I'll be running a Four Wheel Camper at times on my Tacoma, but want the ride quality of the standard springs when the camper isn't installed. I'm going to install Airbags and Daystar cradles for use when the camper is on the truck...should be the best of both worlds.
    Hodakaguy
  6. Jan 14, 2018 at 2:33 PM
    WorKinJoB
    Drew
    Yeah I’m going to call headstrong one day this week. Thanks for the info.
  7. Jan 14, 2018 at 2:36 PM
    OnHartung'sRoad
    Lots of info on towing- I skipped airbags as they limit your extension being they are bolted top and bottom, I love the way my single leaf works and rides with my trailer, and without a load. But it sounds like you may have a lot of constant weight and would benefit by adding a whole leaf pack as airbags do not strengthen your existing springs.
  8. Jan 14, 2018 at 4:04 PM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    Had a bad experience with daystars and rite right air bags. You loose almost two inches of up travel and the airbags have no bump stops. I recommend just buying a set of springs and dealing with the ride when the camper is off. At least u won’t be bottoming out on the air bag mounts all the time or running really high psi to stop the bottoming out.
  9. Jan 14, 2018 at 7:35 PM
    Korndog1284
    Korndog1284 Well-Known Member
    J03l
    Washington
    2016 Off Road DCLB MGM
    All-Pro Raack Pack, Tepui Tent and Awning, ARB BP-51, K02 275/65/17, 4Runner Pro Wheels
    when installing the hd leaf you will likely need to replace the u-bolts and the centering bolt. I bought a set of bp-51s with the hd leaf and needed to replace the bolts as they weren't long enough
