Adding a lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rustic2", May 30, 2016.
  1. May 30, 2016 at 8:02 PM
    Rustic2"
    Rustic2" [OP] Member
    Ethan
    2002 white Tacoma TRD 4x4
    Rims Blistein lift 5100 3in Brush guard Took box Lights
    I currently have a 3in suspension lift on my taco. Kinda want a little more to ensure clearance for bigger tires maybe 33 or 35s ideal. Any ideas on how i can achieve a few more inches?
  2. May 30, 2016 at 8:26 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Think the other post you made about this question covered all your options? Drop bracket lift or body lift is really your only options. You also should be able to fit 33's now With your current lift ,good luck.
  3. May 30, 2016 at 8:35 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    33s will fit your setup with trimming and work/look good. 35s are alot of work and money as a regear is pretty much required to drive it worth any sense.
  4. May 31, 2016 at 12:27 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    suspension wise you are maxed out.. any other stretch will wreak havoc on your CVs and make the ride really stiff with no downtravel... like mentioned above, body lift is the only option for the sake of tire clearance, but that's a whole other animal... and the regearing of front and rear differentials for 35s can be even more expensive... if you really want to go through all that, more power to your wallet...
  5. May 31, 2016 at 8:48 AM
    usptwins
    usptwins Well-Known Member
    Trey
    Louisiana
    Taco SR5 Stock stock stock
    Kyb shocks/struts, Nitto Terra Grappler G2's in 285/70R17.
    Yall all lie! He can add more suspension! But its called LT suspension. And that costs more than you prob want to spend. lol
  6. May 31, 2016 at 9:41 AM
    devinzz1
    devin
    2023 aclb trd or mt
    Lt and sas is a whole different ball game.
    FirstGen Jer likes this.
  7. May 31, 2016 at 9:47 AM
    603fishhunter
    603fishhunter Well-Known Member
    Forrest
    New Hampshire
    2014 tacoma 4 cyl access cab
    6" rough country lift
    I have a 6 inch drop bracket and its not very forgiving. If you want more lift for tires and don't want to trim away than just do a little body lift. I'm not an expert but it should be cheap and easy compared to the other options. 33's do look nice on a 3 inch lift though if you make them fit.
  8. May 31, 2016 at 11:54 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    I just find body lifts a little goofy with the gaps in between body and frame. It's a bit of modification to shift everything to look just right.
  9. May 31, 2016 at 1:31 PM
    Rustic2"
    Ethan
    What rim size would you recommend?
    I have 16x8 now but thinking going bigger and wider.
  10. May 31, 2016 at 4:53 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    going wider will lead to some rub... 8 inch is a good size wheel unless going for the Hawaiian look...
  11. May 31, 2016 at 11:42 PM
    supraskills
    supraskills New Member
    JT
    1998 TRD Tacoma, 4x4
    Good thread.
  12. Jun 1, 2016 at 2:00 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
