Adding a little bass
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paul123, Apr 12, 2016.
  1. Apr 12, 2016 at 9:03 AM
    Paul123
    Paul123 [OP] Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    Has anybody ran one of these? I just want a well rounded system, and to have a little more low end where the stock system is lacking in my 2014 non jbl. Do you think this sub is a good value for the price, or not worth it?
    Kenwood KSC-SW11 Compact Powered Enclosed Subwoofer https://www.amazon.com/dp/B00BO8O9XQ/ref=cm_sw_r_cp_awd_JUrdxbWQ2VCAD
  2. Apr 12, 2016 at 9:22 AM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    I have a small amp and a 10" behind my rear seat and it sounds great. Nothing special but it is clear and has some nice base. I am 42 years old and all I want it to hear the music the way it should be heard.
    If you turn off the base to the stock speakers, you would be amazed at how loud and clear they are, it's the base that distorts it all. My base is controlled from my amp, my door speakers have none.
    I think what you are looking at would be suffice, but make sure whatever you do it amplified.
  3. Apr 12, 2016 at 9:27 AM
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    ^ for the love of god. It is BASS.
    SDtacoTK, jmaack, whiting1977 and 5 others like this.
  4. Apr 12, 2016 at 9:29 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I've been looking at removing my JBL deal and putting this in. I plan on relocating my batteries to the JBL sub area.
  5. Apr 12, 2016 at 10:00 AM
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    That's pretty neat but the low price scares me a little bit. I'm only one step up from retarded when it comes to sound systems but with my limited experience, I've learned you get what you pay for. That being said, the low price also makes it worth a try. Set your expectations low and I'm sure you'll be happy with it.
  6. Apr 12, 2016 at 10:04 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    If you guys can hang on a little while longer i have way more powerful self powered units coming shortly. Believe it or not, ill be getting 2 in. One a 200wrms application and the other a 400wrms application w a response down to 18hz
  7. Apr 12, 2016 at 8:23 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I have no direct experience with the Kenwood unit listed, but I normally hold the the same "get what you pay for" belief BDL5589 mentions above. That said, I was very happy with the similar Sound Ordnance B-8PTD I ran in my '04. For me, it did exactly what you're looking for - rounded my (aftermarket) system out with a little more low-end that what it originally provided. Bottom line: I thought the Sound Ordnance B-8PTD was a great value. Assuming the Kenwood performs similarly, it should meet your needs.
  8. Apr 12, 2016 at 11:13 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    x2. I did the same thing in my 03 DCSB, but ran 2 of the S.O. B-8PTD. One under each front seat. Low end response was a impressively improved. Not earth shattering, but rounded out extremely nicely. Excellent value. A few of my Taco friends repeated my setup after listening to it in my truck. I still have the gear to swap into my 2nd gen once I replace the head unit.
  9. Apr 13, 2016 at 2:07 PM
    DoctorStrobe
    DoctorStrobe Active Member
    Yes, I installed one of these in my friend's Double Cab Tacoma last year. Still going good.
    I put it behind the driver side rear seat. It fit well back there. It would have fit under the driver's or pass seat but it would take up foot room for passengers so we didn't do it...
    It sounds pretty good. It has enough bass to be 'annoying', but it's not going to 'shake the world'.
    I do think it was a bit 'boomy' though. A bit too heavy on the upper bass region.
    It's still probably the best option if you need to mount it out of the way though.
    I personally went with one of these: http://www.rockvilleaudio.com/rtb80a/
    I bought it from Ebay.
    It won't fit behind the seats though. I just let it roll around in the back of my double cab...
    Again, it's not super loud but It's very 'tight' bass. A song with a good bass drum track sounds really good.
    I like this one better than the Kenwood. Especially for the price.
    I have it wired with connectors so I can easily remove it if I have a lot of passengers.
  10. Apr 13, 2016 at 7:31 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Such different things. Amazing what a single letter can do!
    BASE
  11. Apr 15, 2016 at 2:55 PM
    Paul123
    Paul
    Reno
  12. May 9, 2016 at 5:50 PM
    MacDougl
    MacDougl Active Member
    Greenville, Texas
    '10 Access Cab 4x4
    Window visors, fog light mod, bed storage locker locks, aftermarket stereo, lighted 4x4 switch, lighted console
    Still happy with this? I replaced my stock speakers but bass is lacking. Was wondering about sliding this under a seat.
  13. May 9, 2016 at 10:00 PM
    Paul123
    Paul
    Reno
    Yeah it hasn't done me wrong yet, it got a little deeper after it broke in some
  14. May 9, 2016 at 10:18 PM
    qdude79
    qdude79 Active Member
    Central Cal
    '15 PreRunner DoubleCab V6
    Debadged, Maxtracs, F5's on 285s and Ride Rites
    Can I/we get a little more info on this? Where will it install? Under a seat?
  15. May 9, 2016 at 10:27 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I have been really happy with the bass output of simply replacing the stock speakers with some good pioneer 6x9 3 ways up front and 6.5 round 3 ways in the rear. Far better quality sound than stock, really woke up the stock head unit. But i could see one of these lil subs being a nice addition as well.
  16. May 10, 2016 at 7:11 AM
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    Did going to aftermarket speakers make the sound any louder? I like to ride around listening to music with my windows down in the summers, but when going down the highway I need to turn the volume up above 40 and anything louder than that the poor factory speakers sound like they're going to burst.
  17. May 10, 2016 at 8:12 AM
    nd4spdbh
    SoCal
    Oh big time, It might take maybe 5 more volume to achieve the same loudness. BUT you can crank it all the way (up past ~40 where the stock speakers would get super distorted) and the sound is still clear and not distorted like the stock speakers. Seriously do it if you are even considering it. The stock speakers have a driver that literally the size of 6 quarters stacked. ITS TINY, the pioneers that i put in place while not super high end, were built AMAZING, and are HUGE compared to stock.
    FYI i did this, did not do the sound deadening, and made my own tweeter adapters out of a piece of aluminum flatstock (super easy). Also note that factory wiring colors for the tweeters are backwards, black is positive, red is negative, just follow the wires back to the main harness and you will see what i mean.
  18. May 10, 2016 at 8:20 AM
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    Any updates on this offer?
    RJM
  19. May 10, 2016 at 8:22 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    It will most likely ship with the deadener group buy and i hope to do one of these as a prized draw as well. We will see, it will depend on volume. IF not they will all be sent direct. Which one are you interested in the most ? under the seat or the 400wrms 10
    Mongoose likes this.
  20. May 10, 2016 at 8:43 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Its weird the magnet for the stock tweeters is like twice as big as the magnet for the stock 6x9's. o_O
