Adding a rear locking differential 3rd gen Sr5?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 17T@coma, Jun 1, 2024.
  1. Jun 3, 2024 at 7:29 AM
    turkeyslayer66
    turkeyslayer66 Well-Known Member
    mike
    22 AG Trd Sport
    Would you have to turn off the traction/stability control when using an aftermarket locker on a truck that did not have a oem locker?I'm guessing trucks with oem lockers have programming to disable the traction control braking to rear axle when the locker is engaged, keeping the system from fighting itself? I honestly think a true-track style unit might be better all around for the uses O.P. is going to do according to post. Either way, both systems will help a lot, especially if there is some weight in bed and good tires.
  2. Jun 3, 2024 at 10:16 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    There would be no shipping down time. They'll ship you a built one, you tear yours out, you install the built one, and then ship yours back for the core charge refund.
  3. Jun 3, 2024 at 10:18 AM
    ShimStack
    Ben
    NC
    You can plumb any pressurized air source to test. I recommend doing a leak down test before going through with the install anyway.
    BabyBilly[QUOTED] likes this.
  4. Jun 3, 2024 at 10:24 AM
    ShimStack
    Ben
    NC
    No, you can let the systems function.
    Traction control will basically work as normal and for the auto-LSD type functions that sense cross axle slip they'll just never intervene because it'll never see cross axle slip with a locker. With a mechanical LSD the auto-LSD functions are even more effective.
    Stability control only creates an issue if it wants to brake a single wheel for corrective action and the axle is locked. The outcome the system expects will be different than anticipated since it's effectively braking on the entire axle and not an individual wheel.
  5. Jun 3, 2024 at 10:25 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    Fair point. I didn't consider that
    ShimStack[QUOTED] likes this.
  6. Jun 3, 2024 at 10:38 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    What kind of off roading are u planning on doing ? Lockers are good for situations only not to be used all the time . From the looks of your truck u definitely will not need a locker since your setup would not even be able to get in those areas that would require using a locker . Just my 2 cents … your truck is more than capable of doing normal trails without a locker .
    joshrighthere likes this.
  7. Jun 3, 2024 at 10:38 AM
    Bill0351
    Bill0351 Well-Known Member
    Bill
    2023 SR V6 4x4
    Tires/Cap
    My advice would be to upgrade your tires before you do anything mechanical. My Duratracs are loud, look great, and even though I have used my 4wd quite a bit, 90% of the time I could have gotten through without it, and I was searching out places that looked challenging. I used to get my work van so far off the road most 4x4s would have thought twice using nothing but the stock LSD and AT tires.
    BabyBilly likes this.
  8. Jun 3, 2024 at 10:41 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    This is what i would use on my 2016 2WD.
  9. Jun 3, 2024 at 11:07 AM
    turkeyslayer66
    mike
    22 AG Trd Sport
    Good info, thank you!
  10. Jun 3, 2024 at 11:26 AM
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    Auto LSD on the Tacoma's work surprisingly well. Got me out of quite a few jambs over the years.
    Bill0351 likes this.
  11. Jun 3, 2024 at 11:37 AM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    I put an arb air locker and it costed me almost 5k with parts and labor, labor was like 1100 I put it in my cubby in my bed so I had to buy a cover for the cubby and then I bought the ch4x4 switches since they look oem and I had to buy a special wiring harness going to the engine
    it’s been about two years haven’t had any issues if I had to do it again I probably would have went with an Eaton locker just because it’s cheaper and I wouldn’t have had to buy all the crap that I did
    StreetSr5 likes this.
  12. Jun 3, 2024 at 11:40 AM
    StreetSr5
    StreetSr5 Well-Known Member
    This. I love my Truetrac. Around town it acts like an open diff until you loose traction. Kinda fun how it spins both wheels when I do a burnout or swing it (not that that matters anyway:D) And yes, if one wheel is off the ground an lsd won’t work, but if you press the brake or even engage auto lsd the Truetrac spins the wheel on the ground, basically acting like a locker. Truetracs are also bulletproof as well, they don’t have clutches that wear out, and are overall much stronger than the stock spider gears. I paid 1400 total for it, 700 for parts and yeah 700 for labor I live in the Bay Area so that was the lowest quote i got. If OP you go with a locker be prepared to pay! But you won’t go wrong with anything you do, they’re all better than the stock diff
    SHADOWDRIFTER19 and Bill0351 like this.
  13. Jun 3, 2024 at 11:44 AM
    17T@coma
    17T@coma [OP] Member
    Nick
    17 V6 Tacoma
  14. Jun 3, 2024 at 11:46 AM
    17T@coma
    Nick
    17 V6 Tacoma
    Yeah that does seem a lot more reasonable.I live in the Bay Area also. Where did you get the work done if you don’t mind me asking?
  15. Jun 3, 2024 at 11:55 AM
    #35
    StreetSr5
    I went to United transmission and differential shop in Albany. I got quotes as high as 2000 for labor, so I called around a lot. The Albany shop was the closest to me and the lowest price, they also let me provide parts my self so I was able to save money there. They also got it done the same day. The second choice was shaffers off-road in Union city, they also quoted 700 for labor but it was farther and they were booked out for a month.
  16. Jun 3, 2024 at 12:00 PM
    #36
    joshrighthere
    joshrighthere Active Member
    Josh
    2019 Black Taco
    This^ just adding my 2 cents as well, if you’re not crawling, you don’t really need lockers. I got by with my SR5 4x4 on 33s. Especially if your truck is your daily, a locker is an expensive mod to nearly never being used.
  17. Apr 21, 2025 at 1:26 PM
    #37
    taco1978
    taco1978 New Member
    Simon
    2019 Tacoma SR5
    None so far
    Did you ever get it done? I’m looking into doing the same.
  18. Apr 21, 2025 at 1:51 PM
    #38
    yotadust
    yotadust Well-Known Member
    SR 4X4 OFFROAD
    have you thought about taking the cash and putting it towards a trade for a stock 4x4 or 4x4 with a locker? Messing with the diff could affect the resale on your truck and possibly prevent you from being able to trade it in in the future.
    Chew likes this.
  19. Apr 21, 2025 at 2:04 PM
    #39
    Lock24
    Lock24 Well-Known Member
    Western Washington
    Now: 2022 SR5 DCLB V6 4x4 (Was: '24 SR5 DCBL)
    Can't remember how many years its been, but 4Wheeler or 4Wheel & Off Road magazine (remember print magazines, LOL) did a test between a stock 4x4 (think they used a Ranger back then) and the same model Ranger, only 2WD with an aftermarket Detroit locker, and went off-roading. IIRC, they also made sure they both had the same brand/type and size of tires to keep things consistent for the experiment. The 2WD with the locker went more places than the stock 4x4. The key was the 4x4 would lift a tire either front and/or rear, and then end up with no power to the tire on the ground even with a LSD, whereas the locked 2WD always had at least one tire with traction at all times. It was eye opening for the 20 something me at the time. Definitely made me a believer in rear lockers if one goes off-roading beyond a light trail or fireroad.
