Adding a second switch to my lights
Discussion in 'Lighting' started by rollin904, Sep 19, 2017.
  1. Sep 19, 2017 at 5:23 PM
    rollin904
    rollin904 [OP] Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Trying to figure how I could wire this: planning to install led reverse/aux lights in my rear bumper. Can I have a switch in the cab and also in the bed of the truck? Would the switch in the bed need its own power/ground/relay, etc?
  2. Sep 19, 2017 at 5:28 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Sep 19, 2017 at 5:32 PM
    Clearwater Bill
    Billy
    Largo Florida
    Do you want them to come on when you are in reverse automagically, or just manually when you need some extra boost?
    rollin904[OP] likes this.
  4. Sep 19, 2017 at 5:35 PM
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Manually. Don't want to blind anyone in parking lots but would rather use them when camping or backing up in the woods
  5. Sep 19, 2017 at 7:04 PM
    Clearwater Bill
    Billy
    Largo Florida
    Interested in same. Have a couple of ideas, but interested in seeing what the experienced recommend.
  6. Sep 21, 2017 at 10:49 AM
    kwalton
    kwalton Well-Known Member
    Baltimore, Md
    2017 MGM DCSB Sport 4x4
    There are a bunch of different ways to do this. If you simply just want 2 switches to turn on the reverse lights that is pretty easy. Just use a 2 wire toggle and one side will go to ground and the other will go to a relay. It may be a good idea to add a diode for each switch to isolate them from each other as well. Then using on relay to activate the lights.
    Wire the relay as follows
    85 - ground coming from the 2 switches
    86 - constant or switch source of 12v fused appropriately
    87 - 12v constant from battery also fused appropriately
    30 - out to 12v in on the lights
  7. Sep 23, 2017 at 7:07 PM
    Faheygf87
    Faheygf87 Well-Known Member
    2016 Blue TRD Off Road MT
    Diodes are how i did mine. They come on when the relay gets power from the reverse light or the cargo light.
    I fuse tapped the cargo light fuse, with a diode, sending that to the relay. Same with the reverse light fuse going to the same pin on the relay.
    Now my bumper lights come on when im in reverse, or however i have my cargo light switch.
    guyross likes this.
