Adding a snow plow with Apex Front Bumper?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nathaniel, Oct 5, 2016.
  1. Oct 11, 2016 at 8:51 AM
    tgear.shead
    tgear.shead Well-Known Member
    And you should have bought a brain.
  2. Oct 11, 2016 at 9:08 AM
    JStiner
    JStiner Well-Known Member
    11 MGM 4x4 4.0 double cab
    KO2s (32s) with 2inch level
    :rofl::thumbsup:
  3. Oct 11, 2016 at 9:19 AM
    tgear.shead
    Reported.
    JStiner likes this.
  4. Oct 11, 2016 at 9:21 AM
    JStiner
    :rofl:
  5. Oct 11, 2016 at 9:22 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
  6. Oct 11, 2016 at 9:58 AM
    Nathaniel
    Nathaniel [OP] Active Member
    Nate
    New Hampshire
    I want to thank everyone for their thoughts and opinions, even those who are against plowing altogether. I would really like to add a plow, but if I have to do a custom mount (big $$ I assume), I might as well just buy a 4 wheeler with a plow or a used kubota. We will see what my options are. I'll definitely talk to that guy @gusher who has one for sale locally, see if it fits without a custom mount. Thanks again everyone.
    10trdtaco and JStiner like this.
  7. Oct 12, 2016 at 6:16 AM
    tgear.shead
    EVERYTHING will need a custom*ized* mount to fit on a lifted truck. No exception. Plows are very sensitive to angles.
    Not sure why you think it will be horribly expensive though, it really won't be. Some plow makers sell *universal* mounting kits, which are basically a bunch of pieces of metal in a box that you (or your plow installer) will weld together to fit your truck. For example, an Arctic Standard Universal; http://www.arcticsnowplows.com/sites/default/files/manuals/53043.pdf
    If you were going towards Arctic, I would suggest STANDARD DUTY 84". For non-modified Tacoma, they "recommend" light duty 84", and they offer a custom kit for mounting Standard Duty plow to a Light Duty mount, but the light duty mount sits too low to the ground -- I had to cut it up and modify it INTO a standard duty. If I were to do it again, I'd go for standard duty 84" with universal mount, even for a non-lifted Tacoma.
  8. Oct 22, 2016 at 4:08 AM
    Nathaniel
    Nate
    New Hampshire
    So I took the truck to the installer to show him. As mentioned, both the lift and the bumper were a problem. It would have to be custom work, and the installer didn't recommend it given the stability of the mount on the Apex bumper.
  9. Oct 22, 2016 at 4:25 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
  10. Oct 24, 2016 at 1:32 PM
    tgear.shead
    I could see the lower skid plate-ish thing below your bumper interfering with a plow mount slightly, but I think that could be removed. The bumper itself is well above where the plow would mount to.
  11. Oct 29, 2016 at 7:08 AM
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    I have a Western Suburbanite on my Tacoma. It is a light weight plow and works great for just doing my driveway. I believe the mount would come into contact with the lower mounting points on the bumper. Below is a picture of the plow frame mount. Having a two or three inch lift with this type of plow is not a big deal. Sure the lift slightly changes the angles but the mount would not be anywhere near your front suspension.
  12. Nov 19, 2016 at 6:49 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I have had a plow on my lifted Tacoma for five years. It has easily saved me 5-7 thousand dollars and a lot of aggravation. It works perfectly and is easy to install and remove. Automatics are better imo for plowing especially if you have a tow package with the tranny cooler. For doing just my personal driveway it's really really good. Best thing I have bought for the truck, worth every penny.
    Coolerman and tacoburrito like this.
  13. Jan 30, 2017 at 4:42 PM
    pseudomike
    pseudomike Well-Known Member
    Michael LaValley
    2012 DCLB TRD Sport
    I have a plow on my '12 DCLB. I have ome 886's up front and Dakars in the rear so about 3" of lift. I wanted a steel plow so I had my plow shop do a custom install. They modified a set of Tundra Fisher Minute Mount push plates to fit my tacoma. Price for customization was reasonable ~$200. I have a 7"6" Fisher Minute Mount SD on the truck. I was worried plow would be way to heavy weighing in at 475lbs. Truck handles it no issues. I put it on at about 15k miles now have 155k original ball joints etc. I only plow my driveway ~1000ft and a few family members but I live in a snowy part of the country. Have pushed well over 12" of snow with it. I previously had an 80's GMC 2500 for plowing my driveway...my beater...and maintenance was never ending. FYI my Tacoma with 300lbs in the bed, and a Leer cap only weighs about 300lbs less than the GMC 2500. Take her easy and plow with the storm Tacoma are really impressive little trucks!
    tacoburrito and Coolerman like this.
