Adding a trailor- how to hook up lights
Discussion in 'Lighting' started by rpmuise, Aug 16, 2010.
  1. Aug 16, 2010 at 3:44 PM
    rpmuise
    rpmuise [OP] Member
    Springfield
    2009 Tacoma 4cyl
    sr5,hsa,stab cntl,pw,pdl,cruise cntl
    My 2009 Tacoma came without a hitch. I ordered one but I need to wire up the truck to accept the light harness on the trailor. Can anyone recommend a kit? On my last truck, I had to cut wires and splice in a black box.
    Thanks,
    Rick
  2. Aug 16, 2010 at 3:54 PM
    Kazz
    Kazz Active Member
    Calgary
    2010 SR5 4x4
    No Mods yet
    Its very easy to this. You first need to determine if you require 4 pin or 7 pin. Either way go to any local hitch shop or truck accessories shop and buy the wiring harness that is made for your truck. I have a 2010 SR5 without the tow package and I just bought a hitch ( install 1hr) and the 4 pin harness (30min). The kit requires you to remove both tail lights. Remove the connector, install the new T connector. Do the same with the other side. Mine was from reese and it came with a small black box that I'm assuming its some kind of protection circuit. I mounted this behind the drivers tail light as described in the instructions. If you need trailer brakes then a 7 pin harness is required.
  3. Aug 16, 2010 at 3:57 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What do you need, 4-pin or 7-pin? There are plenty of 4-pin adapters that are plug and play. You can find them at autoanything or JC Whitney or probably your local auto parts store. If you need a 7-pin, you need to wire up a brake controller and find power somewhere also.
  4. Aug 16, 2010 at 3:58 PM
    Pugga
    Massachusetts
    damn man, beat me to it! but yeah, what he said
  5. Aug 16, 2010 at 5:23 PM
    rpmuise
    rpmuise [OP] Member
    Springfield
    2009 Tacoma 4cyl
    My trailor is a 4 pin so that's what I need to get, right?
  6. Aug 16, 2010 at 5:27 PM
    Pugga
    Massachusetts
    That's it, very quick, very easy. All you need is a screwdriver. Good luck!
  7. Aug 16, 2010 at 11:16 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Any of the major auto part stores should be able to get you a harness no problem. They have the four pin setup down to a science, no wire cutting necessary.
  8. Aug 31, 2011 at 1:00 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
  9. Aug 31, 2011 at 1:43 PM
    Pugga
    Massachusetts
  10. Aug 31, 2011 at 11:44 PM
    Warhorseforever
    Will
    Sand Lapper
    Thanks man.
