Adding a Trans Cooler to a Tacoma that doesn't. have the factory tow package
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JamisonSR5, Sep 20, 2019.
  1. Sep 20, 2019 at 8:58 AM
    JamisonSR5
    JamisonSR5 [OP] Member
    Jay
    2008 Red Tacoma, Access Cab, 4x4
    Is it possible to add a trans cooler to my Tacoma that didn’t come with the factory tow package? I mostly want it for off-roading and snow wheeling but would also be nice to be in the green while towing. Any help is appreciated.
  2. Sep 20, 2019 at 9:07 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I believe that even in a non tow package truck there is still a trans cooler within the radiator, should be pretty easy to add another typical plate/fin type cooler infront of everything with some extra hose.
  3. Sep 20, 2019 at 9:10 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Yep. Done often.
    I used a Derale cooler.
  4. Sep 20, 2019 at 9:11 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    This is the one im replacing my factory cooler with (i have tow pkg).
    https://www.amazon.com/gp/product/B005XZXBYE/ref=ox_sc_act_title_1?smid=A34W5IA1FZ3R70&psc=1
    I've read its a good idea to bypass the Radiator/trans cooler (non tow pkg) and i've read its a bad idea.. you'll find a good thread about it here
    if you search "LPD 4589" you'll find a good thread about it here.
  5. Sep 20, 2019 at 9:12 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Yes, go to a wrecking yard and pull the cooler, brackets, bolts and lines but snap a pic of line route first so you don’t fuck it up.
    For some reason hear things are crazy expensive on ebay.
  6. Sep 20, 2019 at 9:12 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Mount the cooler up front. Disconnect the return line at the hardline under the radiator. Run a hose from the hardline to the cooler then another from the cooler to the hardline that runs next to the engine.
    FishingInSand likes this.
  7. Sep 20, 2019 at 9:18 AM
    JamisonSR5
    Jay
    I don’t remember seeing a trans cooler on mine. From the others trucks I see the small black trans cooler but mine doesn’t have that. How much pluming do I have to do in order for a trans cooler to be installed? Does the truck have some of the trans cooler pluming on it?
  8. Sep 20, 2019 at 9:23 AM
    nd4spdbh
    SoCal
    Look down the driver side back of the radiator you likely have a line at the top and bottom. those are stock trans cooler lines. Tow package just adds an auxiliary cooler in front of the radiator for extra cooling.
  9. Sep 20, 2019 at 9:29 AM
    JamisonSR5
    Jay
    I will check that. Thanks for the help
    nd4spdbh likes this.
  10. Sep 20, 2019 at 12:49 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I have a pretty good write up in my build thread on the one I installed. I have it daisy-chained with the one in the rad and the tow package one. It's easily done and good to keep the trans happy. I forgot who but someone posted a chart with trans temps and how quickly it degrades the fluid and shortens service intervals. It's interesting.
  11. Sep 20, 2019 at 2:21 PM
    wheeliest
    Json
    TMPE AZ
    my trans should have failed 100k miles ago according to that temp scale :rofl:
    knottyrope likes this.
  12. Sep 20, 2019 at 2:58 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yeah not that I completely agree with it since it's not really manufacturer specific or fluid specific. I would say it's kinda a hey look you may want to pay more attention and not cook the shit for long extended periods kinda thing.
