Adding Additional 220V Outlet
Discussion in 'Garage / Workshop' started by jeverich, Feb 1, 2014.
  1. Feb 1, 2014 at 10:21 AM
    jeverich
    jeverich [OP] Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    Here goes..
    This question seems to be asked quite a bit on the interwebs; actually spent some time talking to my electrician uncle about it as well. Just trying to track down some solid input.
    The basics:
    Currently have a single (1) 220V -- 50 Amp -- outlet in my shop.
    Just picked up a 220V compressor and a plasma cutter..
    At the moment, I'm charging the compressor, then unplugging it and running the plasma. Not a huge inconvenience, but somewhat of a pain to have to plug/unplug.
    My question is this:
    What would be the safest/meet code requirement to add an additional outlet?
    Calculate amperage draw from plasma/compressor and wire another outlet in parallel to the existing one?
    Compressor - 15 Amp draw/2.7 HP Motor
    Plasma - 40 Amp (Max) it's a variable draw
    Tap in the breaker panel, add another 50A breaker and run another outlet?
    Build a "Y" adapter?
    Thanks!
    Jake
  2. Feb 1, 2014 at 10:27 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I thought about doing this as well, but one for my dryer, and another for whatever. From just speaking with a few electrically knowledged people, they said splitting the feed is ok, as long as it's in a box, and the two outlets don't run at the same time if they pull more amps than what the line is rated for. I also thought about a 3 way switch to go back n forth between outlets, but was told this woulod be more of a pain than a gain. So, splitting the feed between two outlets is perfectly acceptable, as long as it's in an eletrical box.
  3. Feb 1, 2014 at 10:41 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    To be safe, add another 50 amp breaker if you have the room in the box, it will allow piece of mind, the compressor and all the other shiza can run off the original breaker, the Plasma then has its own dedicated circuit, best way IMHO...
    I just did something similar here at the Farm, it prevents the occasional annoying breaker pop, I would rather overdo the circuits, everything runs cooler and safer...
  4. Feb 1, 2014 at 11:05 AM
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    I just got the approval.. And yes - I'm going to add another dedicated outlet.
    Calculated my amperage draw on the compressor/plasma - at max draw I'd be right on the edge of that single 50A breaker's capacity. Not really worth it in my opinion.
    Think I'm going to tap into the breaker box; add another 50A 220V Double Pole, run some surface conduit and an additional outlet.
  5. Feb 2, 2014 at 8:36 AM
    Indy
    Indy Master of all I survey.
    The copper costs between a 30 and 50 amp run cam be considerable, depends on how big your shop is. I ran a 30a dedicated for my compressor and a 50a for welder/plasma. About $150 difference between the 2. I had about 80 feet between box and outlet though.
  6. Feb 2, 2014 at 11:18 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    This ^
    If you anticipate having a need for the additional amperage, then disregard.
  7. Feb 2, 2014 at 11:49 AM
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    Added a dedicated 50A circuit..
    Pretty insane; the copper wiring was all behind a locked glass case!
    Going to change my color coding on my ground from white to green, thinking about inverting the outlet as well. Weird, all of my welder plugs are upside down.
  8. Feb 2, 2014 at 12:01 PM
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    :thumbsup:You've got some skills Jake!
  9. Feb 2, 2014 at 12:04 PM
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    Haha well you helped for sure..
    Going to head over in a little bit.. should probably get some paint on those sliders.
  10. Feb 2, 2014 at 12:09 PM
    12thmanhawkfan
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    You've got plenty of time. Throw some paint on my skid plate if you have enough time!
