Adding air to tires when cold
Discussion in 'Wheels & Tires' started by jmasterj, Jan 15, 2009.
  1. Jan 15, 2009 at 10:52 AM
    jmasterj
    jmasterj [OP] Samsonite...I was way off!
    07 TRD Off Road
    Probably a dumb question but should you add air to tires when it is super cold out, say -15? My truck has been sitting outside in these conditions for a few days as well. I know that rubber loses its elasticity as it gets colder. My rears are a little on the low side and my pressure sensor light is on. I guess I don't want to risk a blowout or something like that.
  2. Jan 15, 2009 at 11:11 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    you can add air anytime.
    remember as air temps drop, air contracts and your pressure will drop. as the temp rises, your air pressure will also rise.
  3. Jan 15, 2009 at 11:33 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    what he said. :thumbsup:
    -15 is pretty damn cold -- don't go crazy filling them up tho...
  4. Jan 15, 2009 at 11:44 AM
    jmasterj
    07 TRD Off Road
    Tell me about cold:). It is supposed to feel like -45 tonight with the wind chill.
    So right now the pressure is showing around 26ish and I usually run 32 in the rear, should I maybe put about 30 in?
  5. Jan 15, 2009 at 2:21 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    dang now thats cold.i wood air up to what the side wall calls for unless your tires have issues///cracks/gouges ect.i always TRY to have a long hose after the gauge so your face isnt in the tire waiting for the bang.hope that helped.stay warm,later
  6. Jan 17, 2009 at 1:46 AM
    darkturtleninja
    darkturtleninja 9th level dungeon master
    Illinois
    95 2.7 3rz turd
    cold air intake, body lift, suspension lift.
    you got to be careful once it warms up the pressure will increase... i normally keep around 60 to 65 psi in my procomps.... i aired them up in the garage last time i was working on it and it was around 7degrees out... then a couple days later it got up to 65 degrees and i checked them and they were around 71psi which is way too much.... just be carefull and watch the temp. if the temp spikes up let some air out!
  7. Jan 17, 2009 at 4:46 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Go take a ride, heat up the tires and see what you end up with before you add air.
