Adding amp/sub to JBL amplified system??
Discussion in 'Audio & Video' started by A7XT, Dec 16, 2010.
  1. Dec 16, 2010 at 9:58 PM
    A7XT
    A7XT [OP] Reppin UWYO
    Kyle
    WYOMING
    '09 TRD Sport V6 Silver
    BRUTEFORCE FAB HYBRID BUMPER!, 1.5 AAL, 5100 at 2.5" in front, foglight and DRL mod, fully de-badged, diff-breather mod, aux backup lights, rear view switch on mod, full husky floor liners, yellow wire mod, black action packer toolbox, Rockford P3SD412 sub on a hifonics Zues, Pioneer 4200DVD, hitch recovery shackle, Toyota Ski racks over bed, 55W Bixenon 6000K, Rigid 4" LED bars on bumper, Black Ultra Thunder 17" rims
    Hey guys, I am trying to install a 12" 2ohm pioneer shallow mount behind the seats in my doublecab with stock JBL amplification. I want to keep the JBL headunit because I like it and dont have enough money to upgrade yet. I have searched the forums extensively on this topic and my only question is where to get the signal for a line out converter to give my amp RCA signals?
    I need recommendations on a good high to low converter for under $50 and where to grab the signal for it.
    It seems like on the stock amp there is a connector with input from the head, a 4-pin connector going out to the JBL 8" sub, a connector going to the front 6x9's/8" sub (lows), and one for the tweets and back doors (highs) Should I try to get the signal from behind the headunit, or try to get it from one of these connectors going from the stock amp. Any help is appreciated here fellas and i can get a picture of the amp if needed.
    Thanks!
    Kyle
  2. Dec 19, 2010 at 7:19 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    You're in for one hell of a PITA. My 07 JBL system I do believe is slightly different than yours, but I replaced my head unit and had to buy the digital adapter to convert the signal from the head unit to the amplifier. I think the adapter goes both ways, to-from. Mine cost me around 50 bucks.
    On the other hand you could stick with stock amplifier however, the rear speakers have a high pass filter on them... so its kinda pointless. One of these days I want to gut my system, but it will be some considerable rewiring. The biggest upgrade that I think you could do to a JBL system is upgrade the head unit. I have a considerable amount of bump and really good control over the sound quality. Its not too bad!! Shakes the rear view mirror a bit at least :) Just make sure you buy a decent head unit with a good EQ on it. I don't think you could get decent sound quality with a standard 3 band EQ on a cheap radio. I'm currently using a Premier HU. It's older but does a great job.
  3. Dec 19, 2010 at 7:22 AM
    brian
    Elizabeth City, NC
  4. Dec 24, 2010 at 9:08 PM
    xxsoccafreak09xx
    xxsoccafreak09xx Well-Known Member
    Louisiana
    2009 Prerunner Lifted
    17" dick cepek rims with 33" nitto mudgrapplers tires, 3" lift, Fishing rod rack.
    I am in the same boat as you and i bought an output converter for my 2009 tacoma i just dont know how to install it?
  5. Dec 24, 2010 at 9:11 PM
    xxsoccafreak09xx
    Louisiana
    i believe the output converter i bought cost 25 and is made by metra
  6. Dec 27, 2010 at 8:36 PM
    A7XT
    Kyle
    WYOMING
    Alright fellas I did it :) I bought a LOC for 30.95 shipped from davidnavone.com because it is a great LOC.
    The N-RHL2:
    http://www.davidnavone.com/cart.asp?24&cat=7
    I took out the JBL sub, took the stock amp and moved it to a different location, and pulled the signal for my sub from the 4-pin connector for the stock JBL sub. So with the four wires on the N-RHL2 I put each one into a pin on that 4 pin connector (this will work since each channel on the converter can handle 50 watts and the stock sub has 2 voice coils with about 40 watts each. I plugged the RCA's in to my amp and everything worked perfectly the first time - the taco is bangin with my RF P3SD412 in a ported box! Pics to come in a few days hope this helped
  7. Dec 27, 2010 at 8:47 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Need pics and more details!!!!!!!!!!!!!!!!
    This is what I need to do to help out the factory system and keep my headunit.
  8. Dec 27, 2010 at 8:51 PM
    A7XT
    Kyle
    WYOMING
    Ok man I will do a writeup in the next couple days if I can find some time. I know this would help a ton of people who want to add some bump, or an amp the their JBL amplified system. It was actually a really fun install!
  9. Dec 27, 2010 at 9:22 PM
    A7XT
    Kyle
    WYOMING
    Hmm maybe it was a problem with earlier model years, but my 09 stock amp is a champ so far and you can unplug the stock sub w/ no problems. I still have it powering my door speaks until i can do a full speaker/amp upgrade.
  10. Mar 24, 2011 at 10:35 PM
    twistax
    twistax Toyota Freak
    Carlsbad NM
    2017 Tacoma 4x4 Off-Road
    CaliRaised ditch mounts & Side Projecting pods
    This was on a 2009? If so how did u know which wire on the sub harnes was positive/negative?
  11. Aug 6, 2014 at 8:23 AM
    Gunlex
    Gunlex New Member
    Washington
    2013 TRD Sport Double Cab
    None - 2x 10" sub install pending
    New Link for the LOC
    I have a post looking for info on this for my 2013 JBL amp system and have been digging forever to find a hint, this looks like it may work for me, ordered!
    Curious which wires you used from the 4 pin sub plug..
    I'll get a better pic of the harness and wire colors after work today.
    This may be the correct wiring diagram, I will check it out tonight.
  12. Mar 17, 2016 at 4:10 AM
    AutoEntropy
    AutoEntropy Bonafide Lover
    Jaeger
    Tempe, AZ
    2014 Tacoma V6 Sport 4x4 4dr Super White
    Method Mesh Wheels 17X8.5 Offset 0 Spacing 4.75" BF Goodrich All Terrain TA KO2 265/70 R17 Factory Roof Rack Factory Bed Net
  13. Mar 29, 2016 at 11:05 AM
    FamouzStarz
    FamouzStarz NMSAF!
    2013 Tacoma Baja / Supercharged
    Super Charged, Icon Stage 5, Rigid Grill / Light Bar, Fuel 20" Wheels / Blade Tires, Shell Color Matched, Roof Rack, KatSkinz Interior, and other stuff
    update>?
    other wise my new plan is....
    1. aftermarket deck
    2. jbl harness to keep the amp for door speakers (relocate)
    3. new subs, amp pulling signals from new deck
    never thought the JBL system would make things so complicated!
