Adding amp to non-JBL 2013
Discussion in 'Audio & Video' started by Panzer, Aug 27, 2013.
  1. Aug 27, 2013 at 7:24 AM
    Panzer
    Panzer [OP] Well-Known Member
    Massachusetts
    2013 TRD Sport Black
    Access Tonneau TRD Skid Plate Grillcraft (shortly)
    I know the question has been asked and I cant seem to find an answer. Basically, I want to improve to sound of my setup and want to keep the stock head unit. I am new to this and was wondering what the recommended setup was for this? I was reading an ohm mismatch somewhere as well. I am also considering swapping out the front speakers and tweeters since my drivers side tweeter is already blown! Thanks.
  2. Aug 27, 2013 at 7:34 AM
    Operator313
    Operator313 Well-Known Member
    Dave
    Iowa
    12 TSS Prerunner SR5
    Maxtrac Spindles 2 inch blocks on 1.5 AAl's (You jelly?) Kicker L78 Kicker 300.1 BLHM Color scratched grill
    You can add an amplifier(s) and a subwoofer by installing a line output converter. Be sure to use plenty of sound deadning and use a well built, sealed box or it will sound like poo.
  3. Aug 27, 2013 at 7:36 AM
    Panzer
    Massachusetts
    I don't really want to add a sub. I just want to add an amp to improve sound
  4. Aug 27, 2013 at 8:04 PM
    Riverdog
    Riverdog Well-Known Member
    Collin
    Portland, OR
    '05 Double Cab PreRunner
    What is your budget for speakers and an amp? Are you thinking of replacing the speakers in a four doors? There are a ton of speakers out there in just about every price range.
  5. Aug 28, 2013 at 6:22 AM
    Panzer
    Massachusetts
    I was thinking around 4-500.
    I want to replace the speakers and install an amplifier.
  6. Aug 28, 2013 at 11:42 AM
    Riverdog
    Collin
    Portland, OR
    Before you buy anything, go to several car audio stores in your area and listen to the speakers that are there. This way, you'll hear what you like. You might end up liking one brand over another.
    If this is going to be your first install of an amp, I would recommend buying from Crutchfield. They have really good customer service and can help you if you ever run into any problems. Without knowing what brands you may have a preference towards, I picked out a speaker system that would fit within your budget.
    Front Speakers: Alpine SPS-610C ($130)
    Rear Speakers: Alpine SPS-610 ($100)
    Amp: Alpine MRP-F300 ($150)
    Amp Kit: StreetWires ZeroNoise 3 ZN3K-08 ($35)
    There are tons of setups you could get. This is just what I picked that fit within your budget. Also, you don't have to buy an amp that is the same brand as the speakers. I just did because the Alpine checkbox on the website was already checked. I guess that makes me lazy. However, Alpine amps have a good reputation and you'll likely be happy with this one. Let me know if you have any questions.
  7. Aug 28, 2013 at 11:45 AM
    Riverdog
    Collin
    Portland, OR
    I just had another thought. It may be worth it to buy the system one piece at a time. That way, you can buy higher quality (i.e. more expensive, unfortunately) pieces. For instance, maybe look into just buying the front speakers and an amp now, and pick up the rear speakers later. Anyway, its just something to think about.
  8. Aug 28, 2013 at 11:49 AM
    mclovin
    mclovin chicka chicka, yeah!
    RAFL UK
    16 TRD OR DC Barcelona Red
    Prev, 04 Xtra Cab Prerunner, 12 SR5 4x4 AC
    dont forget the line output converter... this is a must for keeping the stock head unit.
  9. Aug 28, 2013 at 4:05 PM
    Riverdog
    Collin
    Portland, OR
    Oh yeah, thanks mclovin!
    You'll need a line output converter like the AudioControl LC6i ($120)
  10. Aug 29, 2013 at 3:31 AM
    Panzer
    Massachusetts
    Awesome. Thanks for your help with this. Wouldn't I need an adapter (MDF) to get the speakers to fit?
  11. Aug 29, 2013 at 8:52 AM
    mclovin
    RAFL UK
    you will, the crutchfield ones arent horrible but i would suggest Tacotunes for this. i know that they have some bad rep on here but in my dealing with them they actually did screw up my order, but bent over backwards to make it right.
    i also would say close up some of those cavities in the doors as well with dynamat or something. you dont have to go over board, just 2-3 rolls when used sparingly will do the trick! good luck with your project.
  12. Aug 29, 2013 at 10:25 AM
    Tj0hn
    Tj0hn Well-Known Member
    Arkansas
    Stock TRD Sport 4x4
    http://www.tacomaworld.com/forum/audio-video/285434-speaker-adapter-templates.html
    Here ya go. Just print these out and transfer to MDF. I used 1/2" MDF and reference the sticky install thread by Mr. Marv to get sizes for new bolts.
    FYI, these are exact, just rough around the edges.
  13. Aug 29, 2013 at 5:54 PM
    Panzer
    Massachusetts
    You guys are great. I hope to be doing this shortly and will keep you posted.
  14. Aug 31, 2013 at 7:32 AM
    Panzer
    Massachusetts
  15. Aug 31, 2013 at 7:36 AM
    Panzer
    Massachusetts
    As far as wiring and splicing....I know I need to run the cable from the amp to the converter but what about the speakers? Use the stock wiring? Everything plug into the converter behind the dash? Have to run wire to battery? Just like to be 100% with no surprises.
  16. Sep 3, 2013 at 4:26 AM
    Tj0hn
    Arkansas
    Stock TRD Sport 4x4
  17. Sep 3, 2013 at 4:03 PM
    Panzer
    Massachusetts
    Thanks. I found the speakers cheaper but the amp price is pretty good.
  18. Sep 3, 2013 at 4:04 PM
    Panzer
    Massachusetts
    My wife has also said no. Hahaha. It will be a little bit until I can salvage a little cash
  19. Sep 3, 2013 at 4:07 PM
    Yotabilly
    Yotabilly Well-Known Member
    Connal
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    Do you have this? Does it work? I've yet to see anyone on here use a converter and not have an audible hiss.
  20. Sep 4, 2013 at 5:09 AM
    Tj0hn
    Arkansas
    Stock TRD Sport 4x4
    Save yourself the time and trouble and just get a new head unit. A single DIN with Front/Rear/Sub RCA outputs can be had for less than $300 and the sound you get from it trumps the stock unit by a mile.
