Adding an auxillary fuel tank, how to advice needed.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bodhi armor, Jun 7, 2016.
  1. Jul 1, 2016 at 9:20 AM
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
  2. Jul 1, 2016 at 9:25 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    you can't siphon through the filler neck of our tanks (and most modern vehicles). there is a screen before you get to the tank.
  3. Jul 1, 2016 at 5:59 PM
    Axion
    Axion Well-Known Member
    Adam
    Midwest
    daily driver with extra flexibility
    various odds and ends
    The siphon end isn't from the truck tank, it's from the extra gas cans. You can easily direct the non-siphon end of the tube far enough into the truck refueling receptacle to have it stay in place. I have seen one person add an extension to the end of the tube with success to allow him to not remove the tank from the truck bed, though that might not be necessary depending on whatever you have going on with the truck bed (cap, cover, windoors).
  4. Jul 1, 2016 at 7:51 PM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    A lot of farmers, ranchers, and loggers have setups not unlike some of these for their diesel trucks and equipment. Many of them have a large, maybe 250 gallon, tank in the bed of their truck for refueling equipment. I guess if they wanted to run the highway rated fuel in their equipment they could fuel their trucks from the big tank in the bed. With some of the setups in this thread I could fill up just once a week instead for twice per week. Pretty cool.
  5. Jul 2, 2016 at 8:30 AM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Good point about the vacuum. I actually thought it was pressurized, rather than vacuumed.
  6. Aug 2, 2016 at 12:21 PM
    PyriteTRDsport
    PyriteTRDsport New Member
    Shane
    Fort Bragg, NC
    2014 DCSB TRD Sport Pyrite Mica
    Bilstein 6112s w/ 700# king springs and 5160s combo OME Dakar leaf pack General Grabber X3s 295 70 17 Rear disc brake conversion
    Did you drill a hole in the bed to route the hose?
  7. Aug 2, 2016 at 12:23 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yes
  8. Jun 26, 2024 at 8:54 AM
    916ryan
    916ryan New Member
    2016 Toyota Tacoma OF
    @colinb17 How is the set up holding up? Was talking to a coworker and definity want to get something like you have. Can you drop the links to the products used? Thanks
  9. Aug 22, 2024 at 10:17 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it held up well for 10 years, but i actually tore it all out a few months ago when i started Linking my truck. so no more bed or factory tank, jsut a fuel cell now. i had to replace the remote fill hose once due to UV rot, but other than that it worked great the entire time. the marine tank is linked at the bottom of the page. everything else was just random fittings from the hardware and autoparts stores. same with the fuel pumps. i just got the highest flow rate 12V fuel pumps from Amazon.
    since doing this, there are a few good aftermarket setups available now, that come with all of the parts and pieces. some slick ones fit under the bed, where the stock spare tire would go.
