Adding an LSD for Snow Traction.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeDeason, Mar 31, 2022.
  1. Mar 31, 2022 at 6:48 AM
    MikeDeason
    MikeDeason [OP] Well-Known Member
    My understanding is that my 2015 TRD Sport has a brake traction aid which basically uses the brake to act as an anchor point.
    I would like to add a true LSD as I’ve had this on other vehicles and found it helped in the type of snow driving I do
    so which one and which axle.
  2. Mar 31, 2022 at 6:52 AM
    MikeDeason
    Yes it’s a 4x4 and yes I run Hakka R3’s and yes I put weight in bed and no. Not interested in lockers.
  3. Mar 31, 2022 at 6:58 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    2nd Gen Tacoma Sport models up to 2008 had a real LSD.
    IvanhoeTaco likes this.
  4. Mar 31, 2022 at 7:06 AM
    MikeDeason
    2015. So I order Toyota part ?
  5. Mar 31, 2022 at 9:11 AM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Look at the Detroit Truetrac. It goes in the rear. Research it and you'll be impressed.
  6. Mar 31, 2022 at 9:26 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    For most use in snow or ice the traction control you have is superior to either LSD or lockers. For temporary use in deep snow just to get moving a locker can help. But for general driving having an axle locked or using LSD is a disadvantage. The last thing you want in snow or ice is to have BOTH rear wheels spinning. Most roads are crowned with the center higher so water will drain to the ditch. If both rear wheels spin on snow and ice they go downhill. Into the ditch.
    I've had several trucks over the years with LSD. In my experience the advantages are very limited. Between LSD and traction control I'll take traction control every time. In really harsh stuff then I'd skip straight over LSD and go to lockers.
  7. Mar 31, 2022 at 9:36 AM
    Johnny-Airtime
    Johnny-Airtime Member
    2009 Tacoma, 170,000 miles and counting
    Toytec Lift, Toyota Cat-back, Front Light Bar, etc.
    ohcaltexscar and TodayWasTHeDaY like this.
  8. Mar 31, 2022 at 9:36 AM
    Johnny-Airtime
    I've had a Detroit Tru-Trac, great unit, recommend it highly
  9. Mar 31, 2022 at 9:39 AM
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    I just got one installed last month. So far great in the rain a few days ago. Heading out to the trails in a few weeks to really test it out
    ohcaltexscar likes this.
  10. Mar 31, 2022 at 9:46 AM
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
    i have considerable experience with a Truetrac in winter conditions and i can't agree more with what they said ^.
    you will get (and already have gotten) advice that says that the Truetrac isnt good or safe on snow or ice because it will spin you out. this advice is based on not understanding how the Truetrac works (thinking it suddenly locks... which it doesnt).
  11. Mar 31, 2022 at 9:53 AM
    MikeDeason
    Yea. Going to go with the LSD. For type of winter driving I do it works better than open diff with brake trac and I have no use for lockers. This was first winter had to drive the Tacoma daily on long snow commute and I miss lsd.
    Will look into True Trac in the rear
  12. Mar 31, 2022 at 11:12 AM
    MikeDeason
    Assuming sourcing the Toyota parts would be cost-prohibitive
    My Ram 2500 PW had a locking diff and had a limited-slip when not the diff was not locked. Last winter the commute was in an Outback with X Mode which climbed snowy inclines I had all kinds of problems with the Taco
  13. Mar 31, 2022 at 8:19 PM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    Another positive from Truetrac-equipped truck. That thing is fantastic and behaves very well in all conditions - dry/wet/snow.
  14. Mar 31, 2022 at 9:26 PM
    Halligan
    Halligan Old School
    Cam
    BC Canada
    2015 DCSB Gearjammer
    OME 887s, OME Dakar Heavys, 265/70/17's, Truetrac, 6sp manual
    I have a TrueTrac as well. love it. No down side at all.
    Next wire in a switch to disable the stability control and traction control and you have a fun truck in the snow without the fun nannies interfering.
  15. Mar 31, 2022 at 9:36 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Detroit TrueTrac is hands down one of my favorite mods in the rear axle. On my 2015 I swapped out the OR locker axle for the 8.4 to add a TrueTrac and never looked back. The real time torque vectoring is unmatched by any reactionary brake based system.
  16. Apr 1, 2022 at 5:49 AM
    MikeDeason
    Good to hear this. I will have it installed for next winter for sure. Was going to give up on the Taco for my winter commuting.
  17. Apr 1, 2022 at 6:40 AM
    manida
    manida Well-Known Member
  18. Apr 1, 2022 at 6:52 AM
    xaircav
    xaircav Well-Known Member
    Bill
    Wheat Ridge, CO
    '10 TRD Access Cab 6 speed manual
    TRD intake, skid plate, cat back exhaust and short throw shifter. Bilstein 5100 leveling front and 5100 shocks rear. 32” Falken WP AT4W tires on Gen 3 wheels.
    Marshall is correct. When both wheels are spinning side to side traction is lost and the vehicle will fishtail. I had a Cherokee with a Tru Trac and it was great off road but a handful on snowy/icy roads.
  19. Apr 1, 2022 at 7:02 AM
    replica9000
    2019 T4R ORP
    My 08 Tacoma only had the LSD, no traction system. In 2wd only, it did better than my 19 4Runner does in the snow in only 2wd. I feel the traction system on my 4Runner doesn't always help much in 2wd. However, my 4Runner does have VSC, and when the wheels do break loose, it does help keep the vehicle in line.
  20. Apr 1, 2022 at 8:12 AM
    MikeDeason
    possibly but with the LS on my Ram PW I found I would fishtail less (very infrequently) compared to driving with an open diff. And I felt a lot more secure climbing snowy inclines.
