Adding another amp need help
Discussion in 'Audio & Video' started by krisjw101, Mar 19, 2012.
  1. Mar 19, 2012 at 8:43 PM
    krisjw101
    krisjw101 [OP] Well-Known Member
    Kris
    Spokane,WA
    09 Tacoma 4x4
    Autobot in my rear window
    If I have an amp in my rig alread but want to add another for say, a sub, do I have to use distribution blocks to power and ground them both? Or can I run a all new wire kit? So I would have 2 power cables and 2 grounds?
  2. Mar 20, 2012 at 4:24 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    either will be fine. If you decide to do a distribution block, make sure the existing power and ground wires will carry enough current for both amps.
  3. Mar 20, 2012 at 7:34 AM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    IMO, the easier route would be distribution blocks if your power and ground wires can handle the current. You wouldn't have to take any panels apart and it would likely be cheaper too.
