Adding Aux Video to Factory Screen? (2015)
Discussion in 'Audio & Video' started by jarollar, Jan 28, 2016.
  1. Jan 28, 2016 at 6:28 PM
    jarollar
    jarollar [OP] New Member
    Joe
    2015 Barcelona Red Metallic Tacoma SR5
    TRD Black Alloy Wheels
    So i've poked around a little bit, and haven't really found much. Has anyone tried to splice in or add additional video to your head unit? I have the OEM backup camera that works great, but was toying around with adding another camera in the front, or maybe more (I know i'll need a video distribution block) just for a custom, one off kinda thing.
    Just curious if anyone's done it.
  2. Jan 29, 2016 at 11:20 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    after market head units seem to be every ones go to.
  3. Jan 29, 2016 at 11:34 AM
    Turbo-Taco
    Turbo-Taco Well-Known Member
    Randy
    Portland, Oregon
    2024 Toyota Tacoma SR5
    I am using one of theses, http://www.icarkits.com/cars/TOYOTA_TACOMA_2013/V8VIMTY05 , not only does it give you an extra audio/video connection, via an added app under the source selection, it also allows you to use the blocked out functions on the OEM head unit while you are moving...says it works with 2012-2015 tacomas...I plan on mounting a front camera the fits inside the bottom of the toyota logo, if it ever gets here...otherwise seems to function very well.
  4. Jan 29, 2016 at 11:43 AM
    Zac of all trades
    Zac
    fwpfab.com
    How was the install of the kit? Also did the nav work? I have a 2013 w/o nav in the head unit, not sure if that would work for me. Also would need a gps antenna and module im sure.
  5. Jan 29, 2016 at 11:48 AM
    Turbo-Taco
    Randy
    Portland, Oregon
    Mine was plug and play except 3 wires...my stereo didnt have a 10 pin plug so I had to cut 3 wires, per the instructions, and hook them up myself, one for 12v acc, one for 12v constant and a ground....I am able to use all the blocked out functions of the stereo including nav.
  6. Jan 29, 2016 at 12:10 PM
    Zac of all trades
    Zac
    fwpfab.com
    Fucking sweet! I may have to get this then...
