Adding bed stiffeners and have a couple questions while installing.
Discussion in 'New Members' started by Lobo707, May 10, 2022.
  1. May 10, 2022 at 3:32 PM
    Lobo707
    Lobo707 [OP] New Member
    Lobo
    13 Tacoma 4d, LB. Mild build, so far..
    Old man emu with 2inch fit. Camper with racks and Baja flat rack up front. Deck system covering the bed.
    Hello fellow taco makers. I was going to install bed stiffeners to a truck that already has a ARE camper shell on and a deck system covering the bed. Will the total chaos stiffeners clear the draws and should I take the camper off to release the pressure to the sides of the bed.
    buckhuntin-tacoma likes this.
  2. May 10, 2022 at 3:42 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    What do you mean by "clear the draws"?
    The tailgate support cables?
    Yes the TC stiffeners (I have them) don't interfere with the cables at all they're recessed into the bed a tad, inline with the rear most bed attachment bolts.
    You will have to remove the tail lights so you don't drill into them and to be able to fasten the nuts on the backside.
    I also recommend spraying the threads on the bottom with PB blaster or similar as they tend to get corroded and can be hard to remove and you will need to remove them as the stiffeners install under those bolts.
    Yes you should take all the weight off the bed sides and out of the bed and possibly use a ratchet strap to pull the bed rails in until the gaps on your tailgate are even and there's minimal gap between the stiffeners and the surfaces when the tailgate is closed before marking and drilling your bed sides and floor for the hardware.
    Lobo707[OP] and jwctaco like this.
  3. May 10, 2022 at 3:52 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  4. May 10, 2022 at 3:57 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Welcome to the TW
  5. May 10, 2022 at 4:12 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Welcome to TW. I believe the drawers will clear the TC stiffeners. I'm checking with a friend who has the same setup and waiting for his reply. I don't remember him bitching about it so that's a good indicator.
    Lobo707[OP] likes this.
  6. May 10, 2022 at 4:40 PM
    Lobo707
    Lobo
    Awesome info, Key-Rey. I'm running the deck drawers in my bed and was hoping it wouldn't interfere with opening them
  7. May 10, 2022 at 4:47 PM
    Key-Rei
    Key
    Florida
    Oh yeah no they should clear just fine, the tie down loops on the stiffeners don't stick out much and the feet are lower profile than the bed ribs.
    IIRC I've seen at least 2 people running TC stiffeners with the Decked system without issue.
    Lobo707[QUOTED][OP] likes this.
  8. May 10, 2022 at 4:54 PM
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    Welcome to Taco World! I've got Decked drawers and Rago Fab stiffeners, no interference at all.
  9. May 10, 2022 at 5:37 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  10. May 10, 2022 at 8:01 PM
    Lobo707
    Lobo
    Awesome info and love of the truck. A rabbit hole... one hell oh rabbit hole
