Adding better antenna to CB?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Freeheelbillie, Mar 31, 2020.
  1. Mar 31, 2020 at 10:51 AM
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    EDIT: Fixed link to proper CB
    I am installing a CB here soon thinking it'll be this one https://www.amazon.com/gp/product/B005ZLB0E4/ref=as_li_tl?ie=UTF8&th=1
    Question,
    Is it worth it to add a better antenna then it comes stock with for better range/better reception? (I know the proper antenna can make a difference with HAM) Is CB just limited by the watts? If a better antenna will make a difference, what one would you recommend for the above CB?
    Thanks!
  2. Mar 31, 2020 at 11:21 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    The radio you have linked to is not a CB, it is a GMRS radio.
    I don't know a whole lot about GMRS radios, but I wouldn't run a CB antenna with it. I'd be getting a GMRS specific antenna, if it needs one.
    Edit: this is the CB I run. It is also a Midland, and has NOAA & PA functions.
    https://www.amazon.com/Midland-1001...adio&qid=1585679035&sprefix=midland+cb&sr=8-8
  3. Mar 31, 2020 at 11:27 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    OP: be aware depending on what you run there maybe FCC licenses involved.
  4. Mar 31, 2020 at 11:32 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
  5. Mar 31, 2020 at 11:35 AM
    ryfox0276
    Montana
    2013 RC 4x4
  6. Mar 31, 2020 at 11:36 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
  7. Mar 31, 2020 at 11:37 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Really, I clearly need guidance on a good mounted CB too...:anonymous:
  8. Mar 31, 2020 at 11:39 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That is incorrect, GMRS does require a license. Costs $70 and is good for 10 years. FRS does not need a license. Those are walkie talkies that can be picked up at Walmart.
  9. Mar 31, 2020 at 11:39 AM
    ryfox0276
    Montana
    2013 RC 4x4
    Thank you for correcting me. I get gmrs/frs radios mixed up.
    EatSleepTacos[QUOTED] likes this.
  10. Mar 31, 2020 at 11:40 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Only reason I remember is because I know FRS stands for family radio services, and the "family" is what helps me remember.
  11. Mar 31, 2020 at 11:44 AM
    rnish
    Tacoma 2nd gen
    Technically you get a license when you purchase/own a CB. The FCC does not abdicate its regulation powers.
  12. Mar 31, 2020 at 11:48 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    The whole HAM license issue is a hotly debated topic. LOL
    :stayontopic:
  13. Mar 31, 2020 at 11:48 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I run a 6' firestik. Bigger is always better as cb is limited almost exclusively to LOS. I get about 10-12 miles in open areas, it drops down to 2-5 in the city and is dependent on interferences like RF and structures or even vegetation.
    Tiedie and Freeheelbillie[OP] like this.
  14. Mar 31, 2020 at 11:59 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    I'll open the can of worms...
    What's a "great" CB?
  15. Mar 31, 2020 at 12:05 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    None, they're pretty mediocre. I have a strong dislike for them. Had multiple CBs, multiple antennas, tuned properly, different antenna locations, etc. All were mediocre at best, hard to understand my friends. We went to little $30 ham handhelds and the difference is night and day. The license isn't hard or expensive either.
    ryfox0276 likes this.
  16. Mar 31, 2020 at 12:09 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    I was just looking for coms on the trail, not much more. Most of the guys I run with have handheld "walkie talkies"
    I'd prefer to have HAM and CB in the rig at some point as they have different uses IMHO (CB can't talk to HAM)
    In a perfect world, the CB would have mic controls so I can mount the box under the seat and out of the way.
  17. Mar 31, 2020 at 12:14 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's all I use mine for is trail comms. If most of the guys you run with use walkie talkies, why not just get that? Or get a GMRS set up. That license doesn't require a test, and those can talk to FRS radios (walkie talkies), and be either vehicle-mounted or handheld units.
    Bastek likes this.
  18. Mar 31, 2020 at 12:16 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    So https://www.amazon.com/Midland-Micr...+15W+GMRS&qid=1585682111&s=electronics&sr=1-3 might be a good choice?
    Bastek and will.i.was like this.
  19. Mar 31, 2020 at 12:19 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    Technically if you can if you are on the right 11 meter frequency and modify the crap out of your cb. Now if you want to communicate to cb with ham, you have to ensure that you can somehow keep it at or under 4 watts to not break any federal regulations. Now you run into the problem of sourcing or creating the correct antenna..
    Just something I researched as I was interested in doing something like that. It's more trouble than it's worth, which is why it hasn't been done before and both are kept as seperate systems.
  20. Mar 31, 2020 at 12:20 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Midland makes some nice radios if that's the route you want to go. You'll get much better range and clarity out of it vs a CB, plus the antennas are much smaller and less obtrusive. Then just slowly convince others to get them as well so you can all benefit from the increased range. For reference, the FRS radios operate at 1/2 watt. That one you have linked is 15 watts.
    will.i.was likes this.
