Adding Cruise Control.......
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hoodoo Creek, Jul 1, 2013.
  1. Jul 1, 2013 at 5:09 PM
    Hoodoo Creek
    Hoodoo Creek [OP] Member
    All Toyota's
    My 94 has me spoiled with the cruise control. The 1996 doesn't have it. Is it feasible to add it? Where would be the cheapest to purchase one? I was contemplating craigslist. About how much should I expect to pay?
  2. Jul 1, 2013 at 5:19 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
  3. Jul 4, 2013 at 7:38 PM
    Hoodoo Creek
    All Toyota's
    What about going through a wrecking yard? I'd sure like to stick with a Toyota OEM cruise if possible, unless you think it would not be advisable?
  4. Jul 4, 2013 at 7:40 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    First gen is going to be pretty rough to piece that together.
    2nd Gen is much simpler, but the 1st gen needs the stalk, vacuum actuator, and electronics.
    Better off going aftermarket.
  5. Jul 4, 2013 at 7:46 PM
    bellero
    bellero Well-Known Member
    Wainwright, Alberta
    Tacoma 2003
    Sound advice, I would also go OEM as well.
  6. Jul 4, 2013 at 9:25 PM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    Check with your dealership to see if a dealer installed cruise control is still available. I put one on my 02 that I had a few years back, it was pretty simple.
  7. Jul 4, 2013 at 10:17 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    You could rig up a poor-mans CC that is not as full-featured as stock, but still allows you to take the foot off the go pedal and cruise. Thats what I did.
    I installed an actuator from a '99 Camry (no Tacos or 4runners in the yard). I wired up just the clutch mechanism (throttle grabber) in the actuator. Replaced the stock brake light switch with one from that same Camry so that stepping on the brakes de-activates the actuator clutch. Added a switch to the dash. Pretty simple and cheap (don't need a speed sensor, or CC computer, or stalk or new wiring harness.
    Its really a constant-throttle CC, rather than a constant-speed CC. Thats the short version of the install. There were some unexpected techie things to overcome, but it works.
  8. Jul 5, 2013 at 10:32 AM
    Hoodoo Creek
    All Toyota's
    Lots to think about. once the dust settles from the holiday, I'll get in touch with the dealer and the folks Judojohn mentioned. Tan4X4, I love the way you roll, and most everything I do, I think along your lines, but on this truck, I want this cruise control to be a perfect fit. But I appreciate the input from all of you!
