Adding Cruise to my 2016 SR?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by moe2o4, Oct 29, 2015.
  1. Oct 29, 2015 at 11:50 AM
    moe2o4
    moe2o4 [OP] Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
  2. Oct 29, 2015 at 11:53 AM
    Derek G
    Derek G Well-Known Member
    Silverton CO
    2016 TRD OR DC
    I think the ECU is programmed differently.
  3. Oct 29, 2015 at 11:54 AM
    moe2o4
    Corey
    Pittsburgh PA
    That's a possibility.....
  4. Oct 29, 2015 at 11:56 AM
    moe2o4
    Corey
    Pittsburgh PA
    Read this, it was in the description of that cruise control part......
    Testing for prewired condition of vehicle -
    The 2016 Tacoma no longer require horn wire relocation
    1.Place a small towel on the steering wheel just below the airbag.
    2.Locate access holes on either side of the lower steering wheel cover. Take a Torx T-30 and unscrew the airbag mounts.
    3.Lean the air bag forward gently onto the towel but DO NOT UNPLUG IT.
    4.So if you look at the third and fourth picture on the eBay listing, referring to the empty plug location in the third and the white 4 pin plug shown in the fourth pictures , the bottom 2 pins are empty. Take a piece of wire, or maybe an unbent paperclip, and with the key turned to the 'run' position, momentarily short the two pins to each other. If this makes the dash indicator light up, you know you're in a vehicle wired for cruise.
    So to recap. Expose the empty 4 pin cruise harness connector location. Turn the key on to the run position. Carefully, momentarily short the two bottom pins together, taking care not to bend the pins. If your truck is wired for cruise, this will turn the indicator lamp on. Shorting them again momentarily turns the indicator back off.
  5. Oct 29, 2015 at 11:56 AM
    Derek G
    Silverton CO
    2016 TRD OR DC
    Just about all of these trucks use the same wiring harness, meaning the plug will be there, but other items to make a feature work are not.
  6. Oct 29, 2015 at 11:57 AM
    moe2o4
    Corey
    Pittsburgh PA
    Guy said if you short the two wires and the cruise light comes on the dash your good to go and short them again to turn it off.....
  7. Oct 30, 2015 at 8:53 AM
    moe2o4
    Corey
    Pittsburgh PA
    Bump! Anyone else ever do this?
  8. Oct 30, 2015 at 9:45 AM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    I did this stuff for years, buying the cheapest truck and then adding options to it. I now buy the truck I really want. Trade it in for an SR5. ;-)
  9. Oct 30, 2015 at 9:45 AM
    moe2o4
    Corey
    Pittsburgh PA
    Lol
  10. Oct 30, 2015 at 10:00 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I did the same with cars.
    Not worth it in the end. once you start doing all the add ons yourself its so expensive. an option that was 800 from the dealer cost me 1300 to do myself after buying all the parts from the dealers
    Dagosa[QUOTED] likes this.
  11. Oct 30, 2015 at 10:57 AM
    Derek G
    Silverton CO
    2016 TRD OR DC
    Not to mention that even with the add-ons when it comes time to trade the dealer is going to look at it as whatever package it was when you bought it regardless.
    Joe23[QUOTED] likes this.
  12. Oct 30, 2015 at 11:05 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I would think you should likely be able to add the switch and it should work without issue.
    The parts did not change between 2015 and 2016 for the switch or the harness. :)
    Jeff
    moe2o4[OP] likes this.
  13. Oct 30, 2015 at 12:14 PM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Don't know how many hours I wasted, installing aftermarket stereos, cruise controls and messing with the f'n seats on with the cheap crappy seats that come with low end models. My wife taught me because I would buy a cheap model truck and she would buy an upper Accord Lx or Ex . She would just shake her head when I came home with those crap trucks with vinyl bench seats and just an am/fm radio.
  14. Oct 30, 2015 at 12:15 PM
    moe2o4
    Corey
    Pittsburgh PA
    Going to follow those instructions and see!
  15. Oct 30, 2015 at 12:15 PM
    moe2o4
    Corey
    Pittsburgh PA
    All I added was a Intermittent wiper switch that took 10 minutes to install lol.
  16. Oct 30, 2015 at 12:17 PM
    Joe23
    it cost me 1300 for the factory nav system from VW, after installing it I found out the electronic control module didn't support it and it wasnt turning off when the car was off causing battery drain...new module cost another 500
    steering wheel swap cost me 1500 because again needed a new module.
    Just not worth it anymore. Rather just buy it with everything.
  17. Oct 30, 2015 at 12:20 PM
    moe2o4
    Corey
    Pittsburgh PA
    True but I don't plan on adding navi cause I don't need it lol. I love adding mods to my trunk cause it makes my truck my truck and it can be something that someone else doesn't have!
  18. Oct 30, 2015 at 12:28 PM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    I like toys which have now become necessities that came on new OR truck that I would not have gotten on the SR. The price difference was just $6k on a 2015 model.
  19. Oct 30, 2015 at 8:59 PM
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    sub'd for outcome
  20. Nov 8, 2015 at 7:16 PM
    Daffyduck
    Daffyduck Member
    2016Trd Dblcab Or
    Added one to my 2006 Tacoma was just plug and play. Be careful taking off the airbag. Had to cut a hole with a round hole plug cutter for the cruise control stalk, overall pretty easy
