Adding CruiseControl on Manual 07 Tacoma 2.7 Reg cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WC_firefighterUS, Mar 16, 2016.
  1. Mar 16, 2016 at 10:12 PM
    WC_firefighterUS
    WC_firefighterUS [OP] New Member
    Will
    2007 Tacoma 2.7 4WD RegularCab
    N/A
    Ive been looking at quite a few forums to find info on adding cruise control to my 2007 Tacoma, 2.7 Reg cab/4WD. I'm just curious if there is a kit that is compatible for this year and model. Also, I plan on putting it on myself.
  2. Mar 17, 2016 at 1:31 AM
    rj112275
    rj112275 Member
    Memphis
    2015 Access Cab 4WD
    I'll start off with a yes, there should be a kit out there. Rostra comes to mind. You'll also need to make sure you have the clutch disengage switch and wiring to install, in addition to the cruise control handle. I think that will be all you need. I went with factory parts, just because I'm OCD and like to have factory matching parts. Might check out the thread below also:
    https://www.tacomaworld.com/threads/diy-oem-cruise-control-install.2736/
