Adding DRL???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GoHuskers, Jun 23, 2015.
  1. Jun 23, 2015 at 7:18 AM
    GoHuskers
    GoHuskers [OP] Well-Known Member
    Nebraska
    2012 White DCLB TRD Sport
    Hello all,
    My 2012 TRD Sport does NOT come with DRL. What will it take to add one? Can you please help?
    Thanks in advance.
  2. Jun 23, 2015 at 7:22 AM
    DrFunker
    DrFunker Well-Known Member
  3. Jun 23, 2015 at 7:43 AM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    you have to take apart the dash to the left of the steering wheel and swap out your current blinker relay for the DRL relay/jumper. I did this a few months ago. The step by step in the thread is pretty good, but i do not think it was easy. You have to tug on/disconnect a ton of wires, and the potential to damage something is high i.m.o. My dash doesnt fit together quite right anymore after doing this. I must have broke a clip or something.
  4. Jun 23, 2015 at 12:19 PM
    GoHuskers
    Nebraska
    Thanks for the thread...seems complicated.....
  5. Jun 23, 2015 at 12:20 PM
    DrFunker
    It is actually not that bad. I thought the same thing.
    Go slow, be patient, use the right tool for the job.
    I know there is more to add but I will stop...
  6. Jun 25, 2015 at 2:18 AM
    EsJ TX
    EsJ TX Well-Known Member
    Eric
    Victoria, Texas
    2013 Tacoma 4x4 Double Cab
    5100's , OME 887's, 1/2 spacer driver side, 1/4 spacer passenger side and AAL in the rear 275/70/17 BFG KO2's
