Adding equailzer amp
Discussion in 'Audio & Video' started by newertoy, Aug 27, 2011.
  1. Aug 27, 2011 at 10:18 AM
    newertoy
    newertoy [OP] Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Have already put in a new head unit. Have the factory upgraded system w/amp. Where the hell is it?? The factory amp is not sufficient. (Speakers already upgraded)Purchased an equalizer w/amp(300W). Want to bypass factory amp. What is the wiring pinout(in) for the amp. Wanted to hook up the new system to the factory wiring without running new wires to the speakers. Can someone point me to the info that I need.
    Searched and searched--most info is for 2nd generation.
    As you can see --mine is a 2003-1st generation
    Do I need to download the factory service manual?
    Thanks in advance.
  2. Aug 27, 2011 at 4:22 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    link to "eq amp"?
  3. Aug 27, 2011 at 10:58 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    http://www.pyramidcaraudio.com/itempage.asp?model=906VL
    The manual is on the lower right.
    Just need the wiring outputs from the 2003 amp-cannot locate them.
    Want to just take the tacoma factory amp output wires and hook up to the added eq/amp output. that way I will not need to run all new wires to speakers.
    The connections to the eq/amp from the radio should be easy.
    Am I correct in this setup--seems to be the easiest way.
  4. Aug 30, 2011 at 11:04 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Problem solved--NO EXTERNAL AMP
  5. Aug 30, 2011 at 11:14 AM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    That eq amp is not the way to go, it is also not 300w. You might actually be better off leaving it stock than if you go with that eq, that thing is like 30 year old technology. My .02
  6. Aug 30, 2011 at 11:21 AM
    Johns Taco
    Albuquerque, NM
    :laughing: Lol, at least I tried to be nice to the guy.
  7. Aug 30, 2011 at 12:30 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    ^I get called a keyboard commando when I'm brutally honest like that...lulz
    And agreed, that EQ is pretty junky. But let me ask you a question since I really do want to help. What are you trying to accomplish by running something like that? What's your goal? There might be a better way to get there.
  8. Aug 31, 2011 at 12:39 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    All I wanted to do--Be able to adjust sound--(equalizer)--not amplify.
    Cannot adjust the radio while driving--radio has capability--but you need to go thru a list--menu ect-cannot do that while DRIVING- Installed unit--It DOES WHAT I WANT.
    Old tech-- THATS OK. I do not want to go BOOM BOOM BOOM DOWN THE STREET.
    Thank for the input!!!!!!!!!!
    The CRAPY THING IS ADEQUATE!!!!!!!!!!!!
  9. Aug 31, 2011 at 12:48 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    ^^ This guy know's his stuff. Listen to him.
  10. Aug 31, 2011 at 4:57 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    I will check it--THANKS
