Adding factory roof rack possible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Tom, Apr 18, 2009.
  1. Apr 18, 2009 at 8:02 PM
    Tacoma Tom
    Tacoma Tom [OP] Well-Known Member
    Sunny Arizona
    07 DBL TRD
    Is it possible to add a factory roof rack to a 07 SR5 TRD TACO? Maybe the holes are already in place under the plastic trim piece?
  2. Apr 18, 2009 at 8:06 PM
    w8n4mud
    w8n4mud There's a mod for that!
    Albert
    San Diego, CA
    2015 Subaru WRX
    Bilsteins 5100's (Front & Rear), GrillCraft, Line-X'ed Skid Plate & Bumper Valence, Blacked out hood scoop, Avid Light Bar and much more.
    Yes you can add it on after the fact. I did. It's actually pretty easy all things considered.
  3. Apr 18, 2009 at 9:42 PM
    Tacoma Tom
    Sunny Arizona
    07 DBL TRD
    Need to make any new holes to install it?
  4. Apr 18, 2009 at 9:46 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    Tag
    I'm interested as well...
  5. Apr 18, 2009 at 9:54 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    nope!
  6. Apr 18, 2009 at 10:03 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    If you have the double cab yes right under the plastic trim you will see the bolts or where they would go pretty easy.
  7. Apr 18, 2009 at 10:21 PM
    Tacoma Tom
    Sunny Arizona
    07 DBL TRD
    That's good news, thanks for the information. So rack and I assume new trim pieces......anything else I need to order?
    Thanks again
  8. Apr 18, 2009 at 10:41 PM
    w8n4mud
    Albert
    San Diego, CA
    2015 Subaru WRX
    You dont even need a new trim piece. The molding is part of the rack. Super Easy.
  9. Apr 18, 2009 at 11:29 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    all you need to order is the roof rack.
    everything below is in the instructions.
    quick run down to ease your minds.
    1- remove the existing rubber molding. underneath is the prefabbed holes which you simply cut off the tape that covers them.
    2- mount a metal bracket to the roof using the front holes.
    3- attach the actual plastic roof rack to the roof and screw it down.
    4- the roof rack is designed for the channel and includes the molding on the ends to finish off the channels. it is all one piece. you'll see when you get em.
    i ordered mine from trdparts4u.com
    they are cheapest for me with shipping.
    hope this helps
    judd
