Adding LED lights with DRL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jun, Feb 16, 2013.
  1. Feb 16, 2013 at 5:33 PM
    Jun
    Jun [OP] Member
    Gainesville, Fl
    08 PreRunner SR5 2WD
    Hello,
    I would like to add an LED light with the DRL mods. I saw a LED strip about 24 inches (cuttable) long at Discount Autoparts and I was wondering if anyone has done this mod with the DRL. I've seen this on other cars and thinking why not have this in the truck. The LED is available in Cats eye which cold be mounted outside with the fog lights but I am not sure about the heat and drilling a hole for the wire. I am planning to buy the kit but at the same time I am wondering if this can be done. The LEd has a 3M adhesive on it so I could mount this just underneath the headlight outside. I am not sure if I would disassemble a headlight for this. I search the forum with no success. Any help is greatly appreciated guys. Wiring diagrams?
  2. Feb 17, 2013 at 6:28 AM
    Cain
    Cain Well-Known Member
    Southern California
    2012 Tacoma
    Chrome don't get you home
  3. Feb 17, 2013 at 6:39 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    ^ pics? How much were they?
  4. Feb 17, 2013 at 6:41 AM
    Cain
    Southern California
    2012 Tacoma
  5. Feb 17, 2013 at 6:48 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    Thanks, I found your posts. I like the way they look.
  6. Feb 17, 2013 at 10:31 AM
    Jun
    Jun [OP] Member
    Gainesville, Fl
    Hey Cain, Thanks for the link. I knew someone must have done this. If you don't mind, Did you incorporate the LED with DRL or you have it on a switch so could turn it on and off. I like to have the LED with DRL mods so I don't have to remind myself of turning it on. You mind showing me the steps or any link of how you installed it? Appreciate any help.
