adding lift block to rear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nick11, Mar 31, 2010.
  1. Mar 31, 2010 at 10:09 PM
    nick11
    nick11 [OP] Member
    07 Prerunner
    3" lift, full stereo system with 2 amps and sub behind the rear seat.
    I just put a camper shell on my 07 Dc Prerunner and I need to lift the back around 3/4 of an inch. I made some blocks at work but I am unsure how to install them. I assume I loosen the u bolts and then jack the truck up at the frame? Any speacial advice would be great - thanks.
  2. Mar 31, 2010 at 10:11 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Make sure when you put them in your rear end stays straight. You don't want it to track.
  3. Mar 31, 2010 at 10:11 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    It's best to have a hole down the center of the block and a bolt going all the way through the block and the leafs.
  4. Mar 31, 2010 at 10:13 PM
    desertdude59
    Yep. Might need longer u-bolts too.
  5. Mar 31, 2010 at 10:22 PM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    I'd skip the blocks and get some aal's. You'd be better off.
  6. Apr 1, 2010 at 3:54 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
