Adding lift to bilstein 5100s?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CleanTRD, Feb 13, 2016.
  1. Feb 13, 2016 at 8:20 AM
    whiskeytacos
    whiskeytacos Well-Known Member
    New York
    '14 DCSB Off Road MGM
    OME 886 springs on 90000 struts Total Chaos UCA OME Dakar + AAL energy suspension steering rack and sway bar bushings SCS SR8 wheels Cooper ST Maxx 285/85r16 Pelfreybilt IFS skid plate Pelfreybilt hidden winch mount broken ass winch Softopper All Pro Off Road OTT pack rack
    iK0NiK likes this.
  2. Feb 13, 2016 at 8:20 AM
    CleanTRD
    CleanTRD [OP] Well-Known Member
    Kareme
    2011 silver trd sport double cab
    4 inch lift,,5100 ride height shocks ,,3 inch block, 18 inch black wheels
    I was gonna get the old man emu three inch coil put the bilsteins down to the lowest setting and leave my three inch block in the rear ,,, so the coils will lift the front of the truck 3 inches to level with the rear block ?
  3. Feb 13, 2016 at 8:25 AM
    CleanTRD
    Kareme
    There's like. Million things to google figure this would be the best place to get correct answers ... Dude
  4. Feb 13, 2016 at 8:25 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    You're trolling me right? Search 885 coils, there's a ton of information on here.
  5. Feb 13, 2016 at 8:31 AM
    CleanTRD
    Kareme
    I did Google 885 ,, I was asking about the ome coils because those were the first ones presented to me on this thread ,,, and we drifted away to a different item
  6. Feb 13, 2016 at 10:59 AM
    CleanTRD
    Kareme
    Ok my apologies I figured it out but I'm not finding the 887 I'm finding an 885-886 to fit my 2011 Tacoma trd sport...
  7. Feb 13, 2016 at 11:00 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    You won't find them under tacoma..that's because they are for 4Runners but will work on Tacomas
  8. Feb 13, 2016 at 11:07 AM
    CleanTRD
    Kareme
    So just pick up a set of the 887 s for an 2011 four runner and they will work ?
  9. Feb 13, 2016 at 11:08 AM
    geekhouse23
  10. Feb 13, 2016 at 11:11 AM
    CleanTRD
    Kareme
    I found the 885s and the 886s on Amazon,,, not 887
  11. Feb 13, 2016 at 11:13 AM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
  12. Feb 13, 2016 at 11:21 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
  13. Feb 13, 2016 at 11:23 AM
    HeadStrong Off-Road
    I do what I can...lol....:kona:
  14. Feb 13, 2016 at 11:29 AM
    CleanTRD
    Kareme
    Well thank you I live in ct where is headstrong located ?? Also if I order the 887 coil and install it on my 2011 trd double cab 4x4 it should lift the front 3 inches? I also have the bilstein 5100 ride height shocks on the truck so I would set those at the lowest setting ?
  15. Feb 13, 2016 at 11:30 AM
    #35
    geekhouse23
    It will get you 3" and you leave the 5100's on 0 (bottom) only.
    http://www.headstrongoffroad.com
  16. Feb 13, 2016 at 11:31 AM
    #36
    CleanTRD
    Kareme
    Awesome thanks
  17. Feb 13, 2016 at 11:33 AM
    #37
    CleanTRD
    Kareme
    So Marie I can order these 887 ome coils from you?
  18. Feb 13, 2016 at 11:37 AM
    #38
    HeadStrong Off-Road
    We are in Southern California. The OME 887X coils will provide approx. 3" of lift on an 05-15 double cab 4x4 with the Bilsteins being set at the zero setting. You will need a 1/4" top plate spacer to accommodate for the drivers side lean "Taco Lean" you will notice after switching from factory to aftermarket coils. I provided a link to those as well.
    http://www.headstrongoffroad.com/store/p31/HS_1/4"_Top_Plate_Spacer_-_TT05514-TPS.html
    Please let me know if there is anything else that I can help with.
  19. Feb 13, 2016 at 11:38 AM
    #39
    HeadStrong Off-Road
    You can add the items to the cart from the links I supplied and check out that way. currently all the items you are looking at are good in stock.
  20. Feb 13, 2016 at 11:41 AM
    #40
    CleanTRD
    Kareme
    Ok so just one spacer on the driver side is sufficient?
